RV.Net Open Roads Forum: Fifth-Wheels: Do I have enough Truck?
 > Do I have enough Truck?
Page of 5
Fifth-Wheels Related Tips
4*phun*2
Canada
Posted: 11/05/09 05:02am Link  |  Quote  |  Print  |  Notify Moderator
An RV Dealer would tell you an F150 was enough truck to pull the trailer.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
Bumpyroad
Virginia
fordsooperdooty wrote:
I'm a believe firmly in two things...
1) the right that a free thinking, normal person over the age 18 should be able to pretty much do as he/she wishes as long as he/she doesn't violate my right or the rights of others to live and do what they want to do.
2) Making an informed decision based on all the available information generally involves at some point a tiny little voice in your head either saying "sounds good, go fer it" or "for God Sake don't do it you'll kill yourself!"
Ergo...Human survival has always been based on listening to the tiny little voices in your head!
you forgot:
3) when you know you are doing something outlandish, go to RV.NET and get somebody to tell you that what you are doing is just fine.
4) spend $250 at J.C.Whitney and convert your F-250 into a F-550.
bumpy
M GO BLUE
Southgate, MI
Posted: 11/05/09 05:28am Link  |  Quote  |  Print  |  Notify Moderator
Can you tow it? SURE
Can you tow it safely? THAT'S SOMETHING FOR YOU TO FIND OUT (not something I would be willing to find out with family in the truck)
Will you be overweight on your ratings? MORE THAN YOU PROBABLY KNOW
By the time you get that loaded up you'll be around 13000 or so lbs which would give you a pin weight of ~ 2600 lbs which in my eyes is too much for a single wheel truck
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Onan 5500W Marquis Gold gas generator
KEEP A LOOK OUT FOR OUR SPRING 2010 RALLY!
JIMNLIN
Big Cabin, OK
Posted: 11/05/09 06:10am Link  |  Quote  |  Print  |  Notify Moderator
craig7h wrote:
If you are only going that far I would not worry about it. However if you start "traveling" I would update your truck. Not only do you need something that will be safe you will need something that you can enjoy driving while pulling.
I know you will enjoy your cardinal. come over to the cardinal web site cardinalrvclub.org
good advice for pulling that load only 5 miles.
Your truck isn't a SRW as that designation is for the 3500 SRW. The 2500 is just a 2500. I would be concerned with the rear tires load capacity depending on the 5ers actual pin weight. Most 2500 HD trucks have a 3000+ lb payload capacity, tires and axles, which leaves approx 2500-2700 lb for pin weight before overloading the rear tires. You may need higher capacity E tire if your pin weight is over their capacity.
A chip isn't necessary as it doesn't help your problem of small carrying capacity of the little 2500 truck.
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
rick83864
Sandpoint, ID
Posted: 11/05/09 07:39am Link  |  Quote  |  Print  |  Notify Moderator
I've read a few Tundra owners who have this combo. NO problems, don't even know it's back there. I don't tell my truck its overweight?? Wait till your truck tells you its overweight
06 Dodge 3500 Laramie 4x4 Dually
5.9 Cummins HO Automatic,Jacobs brake, Dodge Navigation
06 Grand Junction 34' Mor/ryde, 5500 Onan genny, Dual A/C, Fireplace
21500 GVW
sue.t
Vancouver Island, BC, Canada
Posted: 11/05/09 07:44am Link  |  Quote  |  Print  |  Notify Moderator
We have the F250 7.3L PSD crewcab shortbox. Our fifth wheel is a 25 footer with a GVWR of 7,000 lbs and a pin weight of about 1,700 lbs when loaded for a trip. On that trip, the fiver actually weight 7,800 fully loaded with water and gear.
If we ever go larger on the fifth wheel, we'll also be upgrading the truck. We've done enough miles with this combination to know that something heavier or longer would make the trip too edgy for our comfort level.
* This post was edited 11/05/09 07:55am by sue.t *
sue t.
Pictures from our many RV Adventures to Yukon & Alaska
MrRepair
North East
Posted: 11/05/09 08:14am Link  |  Quote  |  Print  |  Notify Moderator
kennethwooster wrote:
I'm running a 05 F350 SRW, which will rate about the same weights as you. My trailer is probably a few hundred pounds lighter then yours when empty. We are right on the edge of the weight limits. We have plenty of power. I would not chip the 6.0. We pull up into the Colorado Mountains several times a year which is a little over 400 miles. I would say if you stay local you will be fine.
X2
2010 Jayco Designer 35RLTS
2009 GMC 3500 Dully 4x4,CC,D/A
BruceStarkey
Ontario, Canada
Good Sam RV Club
Posted: 11/05/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Chipping the 6.0 is asking for trouble and if you haven't had any to date with your engine, don't tempt fate. That's the only part of your post I'm going to address as I am not predisposed to becoming just another "pellet" in the load of buckshot you're going to get about 'towing-weights-in-relation-to-trucks' on this forum.
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
USA in a Chevrolet
Manahawkin, New Jersey
Good Sam RV Club
Posted: 11/05/09 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Are you being sarcastic or do you mean that if you look far enough you'll find a dealer which would ok this combo? Sometimes I wonder why people on this forum make these posts. It must be because they got taken by their dealer. Perhaps if you feel this way about dealers you should go to a dealer that has a good reputation. In my opinion, it is just as important to research your dealer as it is the brand of fiver you buy. I do agree that a lot of nice people get taken by dealers, & I am not saying that all dealers are good. Just research your dealer & use common sense. As an example, if you were buying a car or truck, would you believe a salesman who says "this car will get 50 mpg when the door sticker says 32mpg?
larry barnhart
wenatchee. wa usa
Posted: 11/05/09 11:03am Link  |  Quote  |  Print  |  Notify Moderator
We were attending an alpenlite rally at Beaudry's rv in tucson once time so we walked around the rv lot and they had fifthwheels with the correct size ford trucks sitting beside the fifthwheels. I said to the salesman that would a great idea and he pulled out a card that showed what truck could carry the fifth's weight. I agreed with their thinking. I don't remember any 3/4 ton trucks were recommended
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
Page of 5
