exportman
Clovis, Ca
Good Sam RV Club
I have a 32-foot class A on a Chev-workhorse chassis. When I slow down or start up I get a clicking, ticking sound from the wheel on the driver side front. The clicking speeds up as the vehicle goes faster and slows down as I stop. It is only heard while moving. Can't tell if it does it a higher speeds because the engine noise drowns it out. I removed the wheel cover just to see if there might have been a stone in there rotating around as the wheel turned. Nothing was in there.
The question therefore is whether anybody has had a similar problem and what suggestions there might be before I have to bring it down to a dealer. Thanks.
Dutch_12078
Great Sacandaga Lake, NY
Did you try running without the wheel cover in place?
Dutch
'95 Coachmen Catalina 322XL
F-53 chassis, 460 V8
dons2346
Sioux Falls, SD, formerly of So. CA
Good Sam RV Club
Sounds like it could be a loose lug nut. Check the torque on the lug nuts.
Tiger4x4RV
San Diego County, California
Something similar in an old truck I used to have was an improperly installed brake caliper pin. It would click or scrape when moving, then apparently a piece of it would break off and it would be quiet for a while.
aeohio
New Mexico
Good Sam RV Club
I had something like this with my car, I just had the brakes done and they did not put a clip on correctly and it broke and was causing the noise against the rim of the vehicle.
I would take it to the dealer or a mechanic
2010 Passport UL 290BH
2006 Ford Expedition Limited
hwybnb
I agree with Dutch. I sometime get the same thing. Take off the cover on that wheel and see if the noise goes with it. If so, clean the edge of the cover where it contacts the wheel and apply a thin coat of silicon lubricant to it. I have found it best not to torque the nuts that hold it on too tight. If I do it seems to warp the cover and the noise gets worse.
T18skyguy
Eugene, OR
I had the same problem and it turned out to be a loose wheel weight. The clip that held it on was cracked and it was moving back and forth.
Retired Anesthetist. Pilot with mechanic/inspection ratings.1996 Jayco C 22 foot with 460/Banks Powerpak/Bilsteins.Wife and daughter. Two cats which control my life. 1975 Ford F-250, 84 Coupe Deville, Thorp T18, tons of tools and tons of junk.
Artum Snowbird
Campbell River, B.C., Canada
It was quite a time ago, but for me it was the tire treads separating in the tire. New front tires fixed the problem for me.
Mike and Carole
2006 Triple E Regency 27 foot SXL
2005 16.6 Double Eagle
ejforwood
Littleton (Denver) Colorado
Good Sam RV Club
Have you checked for a rock or other item in the tread?
Jerry, Dottie & Chan, "the little furry one"
98 Bounder 34V, 99 F-53 Ford V10 chassis
06 Saturn VUE 4I
Turbo Diesel Dude
Green Mountain, NC
Good Sam RV Club
Had an old 1976 26 ft Winnebago on a Chev P3 chassis and it was the right front caliper rattling. No harm, no foul. JMHO
charles weidman
