RV.Net Open Roads Forum: Folding Trailers: Winterizing My @003 Coleman Cheyenne
 > Winterizing My @003 Coleman Cheyenne
Folding Trailers Related Tips
mattiusr1
Good Sam RV Club
Posted: 11/06/09 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I put three gallons of RV anti-freeze into my water tank with the
intention of turning on the pump and drawing anti freeze up to
the faucet and to the outside shower line, but the only place
that the anti-freeze is going is to the hot water tank, its coming
out because I have the anode removed. Any thoughts will be greatly appreciated.
Guest
Posted: 11/06/09 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Have you ever winterized before? There should be a series of valves and pipes near the water heater that you can rearrange such that flows bypass the water heater. Then you don't need 6 gallons of antifreeze to fill the HW tank first before any gets to the sink/shower.
But it may not have been factory installed. If the camper was always stored indoors heated or in a warm climate, you may need to install the bypass.
He Ruide
Cincinnati Ohio
Posted: 11/06/09 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Paul,
While pouring antifreeze into the water tank is one way to get antifreeze into the system... it is quite wasteful as you have to fill the tank to the pump inlet line before you will get any antifreeze into the system. You can either install a winterizing kit or remove the pump inlet line and insert it into a bottle of antifreeze.
You should also install the water heater bypass kit. If you don't then you will have to fill the hot water tank to get antifreeze in the hot water lines. That means wasting 6 gallons of antifreeze plus it is damaging to the anode.
Hope this helps.
Ruide
Fleetwood Evolution E3 - Yellow (DW let me get a Yellow one since she wanted an E3 with a slide out )
Hummer H2 - Black (DW vetoed the Yellow one, but I got two Yellow Hummer Folding Mountain bikes )
My Pics and Mods and My Weekly Blog
