RV.Net Open Roads Forum: Folding Trailers: Counter wieght
 > Counter wieght
Folding Trailers Related Tips
ARMED2THETEETH
West Coast
Posted: 11/07/09 12:01am Link  |  Quote  |  Print  |  Notify Moderator
I have 550 lbs. tounge wieght. Not bad but would prefer just under 500. Has anyone found a toolbox or mountable container, to load stuff in , for the back bumper of your trailers?
'tiredTeacher
Richmond, VA
Posted: 11/07/09 05:47am Link  |  Quote  |  Print  |  Notify Moderator
Correcting tongue weight by adding more weight may overload your axles and frame. I'd try redistributing the existing weight or removing weight from the tongue first.
Wright and Penny
Tundra 4X4
Starcraft 2107
"Remember to keep it simple. You can't get away from it all if you take it all with you."
http://www.webshots.com/user/awellis3
DIYGuy
TX, NY and all points in between.
Posted: 11/07/09 07:02am Link  |  Quote  |  Print  |  Notify Moderator
If you put a 150 lb. tool box on the back to unload 75 lbs on the tongue, you'll add 225 lbs. to the axle.
As long as the axle can take the weight, and the trailer is still under the GVWR for the trailer, it should work just fine.
FWIW...
Full-Timers, Class of 2011
2002 Volvo VNL770 Toter - Optimus Prime
2007 SpaceCraft - Just Weight
skipnchar
Topeka Kansas USA
Posted: 11/07/09 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Why are you so concerned about a few less pounds on the tongue? If it's important just take some weight and carry it in the tow vehicle.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
mobeewan
Hampton, Va
Posted: 11/07/09 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Tow vehicle hitch may have the standard 500# limit.
Chuck&Gail
In the Colorado Mountains
Posted: 11/07/09 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Note you want tongue weight to be about 13% of the trailer fully loaded weight. What is fully loaded weight? If tongue is too light, you are much more apt to get SWAY.
Also weight added to rear of trailer increases likelyhood of SWAY.
Be careful out there.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
Wildcat63
MN
Posted: 11/10/09 08:09am Link  |  Quote  |  Print  |  Notify Moderator
What pop up has a Toungue weight of over 500 lbs??????????
Wildcat63
07 Coachmen Clipper Classic 1070ST
02 Explorer 4.6 V8 TV
webiknight
Mesa, Arizona
Posted: 11/10/09 08:52am Link  |  Quote  |  Print  |  Notify Moderator
My Starcraft 36RT has over 1000lbs of tongue weight fully loaded.
2006 Starcraft 36RT
1999 Chevy 2500 Crew Cab 7.4L
2002 Yamaha Grizzly
2002 Polaris Sportsman
1999 Honda Recon
When the people fear their government, there is tyranny; when the government fears the people, there is liberty.
Thomas Jefferson
red31
Bryan
Posted: 11/10/09 09:54am Link  |  Quote  |  Print  |  Notify Moderator
How about a receiver hitch welded to the frame so you can use a cargo carrier on the rear of your PU for some of your load?
Rescuebub
Relaxing in MD
Posted: 11/11/09 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
2nd that! I carelessly loaded up one time and had to much weight behind the axles and caused the trailer to be real twitchy. Can you take the LP tank off of the tongue or something like that? Good luck and happy camping!!!!
2002 Roo RLT25FDS
2008 Silerado 2500HD 4X4 Z71 6.0L, 6sp.
Me,DW,DD,2 Pups
 > Counter wieght
