RV.Net Open Roads Forum: Tech Issues: Gally tank is leaking
 > Gally tank is leaking
Tech Issues Related Tips
smkettner
Good Sam RV Club
Posted: 11/07/09 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Gally tank has a small crack in a lower corner. Tank is exposed so access is easy.
Can this be patched? Or where do I find a replacement. Sticker says Travel Star listing #15702 and it is about 30 gallons.
Has anyone done a replacement or am I better at the dealer or Campingworld?
Next trip is in 3 weeks
Golden_HVAC
Fulltime, CA, USA
Posted: 11/07/09 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Contact this place, they probably know a thing or two about it's repair.
Tank-Depot.com
You can measure your stock tank, and the space that it is located in, and probably find a close match on their website. But call them on Monday and see what they have to patch your tank. It probably would be better to remove the tank, then place it someplace so the crack is on top, then the glue has a better change of falling into the crack, not slipping down the side of the tank. And you will ensure that the inside of the tank joint is dry.
Having the tank someplace that is close to 70 to dry in also helps the repair along. But use the glue in a well ventilated area, and move it inside once it has had about 2 hours or more to get rid of most of the nasty smell and fumes.
If they say to sand that area before applying the glue, then you can rough it up with a drill attachment that has a wire brush. But use care not to scrape to deeply into the plastic.
Good Luck,
Fred.
suchristo01
San Diego, CA
Posted: 11/07/09 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
There is a procedure to weld holding tanks. http://www.pellandent.comHas tanks.
Tommy USMC,Susie USN Ret, Dog Buddy
2000 Fleetwood Flair 25F WH P32 7.4L 19.5"
2002 Ford Ranger XLT 3.0L 5 Spd Man
Blue Ox Base,Aventa II,4 PIN Locks
US Gear UTB, Power Gear Man Lev, Onan 4KW
Tent,GP Tent,Tent Trailer,2 Class A's
Are We There Yet?
kneal44
EAST CENTRAL TEXAS
Posted: 11/07/09 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
look for postingsi did on fiberglass repair of tanks.
i had several craacks that i used the fiberglass kit from walmart. will work on most tanks.
worked for me and dident have to change out a 50 gsl tank
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
Dave H M
IL
Posted: 11/07/09 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
I don't see why a fiberglass repair would not work if done properly and enough strength is added to the patched area.
I would look at the other info posted first though.
smkettner
Good Sam RV Club
Posted: 11/07/09 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone tried this: Eternabond A-Seal
skipnchar
Topeka Kansas USA
Posted: 11/07/09 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
In a holding tank that would probably be my first choice. On FW storage tank, not so much
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Gene&Ginny
North Kingstown, RI
Posted: 11/07/09 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
If your tank is ABS (mine is, some are not) then ONLY ABS cement will hold as a repair.
{edit} Is this the freshwater tank or the holding tank?
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Gale Hawkins
Murray, KY
Posted: 11/07/09 09:32pm Link  |  Quote  |  Print  |  Notify Moderator
Agree on the Eternbond route. Years ago our PO bought a grey water tank but before the tank arrived he fixed with a sealer(?) and put a piece of plywood under it and still 8 years later it has not leaked. He tossed the new one into the MH in I have it in storage but hope to never use it but will keep it just in case.
Jerry9n
SE Michigan
Posted: 11/07/09 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
On my maiden voyage with my trailer, the black water valve dragged and cracked the tank where it entered the tank. We didn't notice until we set up. Fortunately tank was empty with exception of a little clean water. Unfortunately it was near dark and I was 12 miles from town and this was the first night of a week stay.
Okay, long story short, I went to a chain auto parts store and bought the putty stick that you kneed. I cleaned and dried the crack and put the putty around it. After another trip to town, I ended up I think with four sticks around it. The putty is supposed to be good for both PVC and ABS (I believe mine is ABS). When I got home, I looked over it, put on one more stick to reinforce it and it is holding a year and several trips later.
I would try that. Google Autozone and check out epoxy sticks--there are several that are purported to be good for both ABS and PVC. The worst is that it wouldn't work and you would have to grind it off.
Another option, when I was in college I patched a gas tank pinhole with Seal All. Might be another option. Neither of these are irreversible.
Jerry9n
2009 23' Cikira Escape EXP
2006 Ford Expedition
Reese Pro Series SC
Tekonsha Voyager
HTT Mods
