webiknight
Mesa, Arizona
I am in the middle of adding an additional water tank to my PUP. The 36RT came with only a 35 gallon water tank. I purchased a replacement tank from Starcraft to up my water capacity to 76 gallons including water heater. I used the same type of tank that came originally with the trailer, because it was already formed to allow the roof lift cables to work properly. I had to re-route a gas line but other then that it went in just like the one that was already there. Here are the pictures:
Rear holding bracket
Front holding bracket
Getting the side brackets in place
Welded and bolted in
Next update - - the plumbing.
edited 12/13/09 08:55pm by webiknight *
2006 Starcraft 36RT
1999 Chevy 2500 Crew Cab 7.4L
2002 Yamaha Grizzly
2002 Polaris Sportsman
1999 Honda Recon
When the people fear their government, there is tyranny; when the government fears the people, there is liberty.
Thomas Jefferson
Golden_HVAC
Fulltime, CA, USA
Hi,
Nice work!
Looks like that was the only place to find that tank, with the consideration for the center being cut-out for the mechanical equipment.
Just remember that 70 gallons of water is about 600 pounds. Hopefully you will have a place for all that gray water too!
Good Luck,
Fred.
downtheroad
Puget Sound
Golden_HVAC wrote: Hi,
Nice work!
Good Luck,
Fred.
I agree - nice work..but also, did you check the CCC (cargo carrying capacity of your PUP? Adding that much extra weight may push you over the rating of tires and axles..Our pop-up had a very low CCC.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
webiknight
Mesa, Arizona
downtheroad wrote: ...did you check the CCC (cargo carrying capacity of your PUP? Adding that much extra weight may push you over the rating of tires and axles..Our pop-up had a very low CCC.
On a normal PUP I would think there may be an issue. The GVWR for the 36RT is 7000lbs. The other concern I had was putting to much weight behind the axle, I counter this weight with the 1200lbs I usually have on the front deck. With both tanks full, the water is still less then 10% of the total GVWR.
edited 11/07/09 07:37pm by webiknight *
campingpapa
Arizona
Nice MOD, I have always wanted to figure out how to add some extra water to my PUP. Don't think this type of MOD would work for me though, my PUPs to little.
beemerphile1
I'm only 54, I'm not a
Good Sam RV Club
I enjoyed reading about your mod. I am currently looking to do a similar mod and add a gray tank to my Aliner because it didn't come with one.
Tim (in NE Ohio)
"Okay, I admit it, the only thing I'm really good at is being me."
2006 Weekend Warrior FK1900 towed by 1998 Ford E150 4.6L
2009 Aliner Sport towed by 2009 Pontiac Vibe 1.8L
1996 BMW R1100GS
2007 Trek 7.2FX
2005 Trek Madone 9spd.
Capt_Leisure
Colorado Springs
Too cool. Doesn't interfere with rear cargo carrier slides either.
2006 Starcraft 13RT - "We found that clowns are universally disliked by children."
nuke1105
San Pedro
do you think this would be safe to do on a regular single axel pup? I want to add another 19 gallon tank underneath my trailer.
mike4947
N. Syracuse, NY
Good Sam RV Club
The almost 200 pounds would have to be located so as to NOT unload the trailer tongue. Low tongue weight can make the trailer untowable due to sway.
Step one get a scale weight and tongue weight on the camper to see what you are starting with as to location and amount of CCC you'll have left.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
webiknight
Mesa, Arizona
nuke1105 wrote: do you think this would be safe to do on a regular single axel pup? I want to add another 19 gallon tank underneath my trailer.
I dont think it would. The single axles dont seem to be beefy enough.
