RV.Net Open Roads Forum: Tech Issues: diesel injectors
 > diesel injectors
Tech Issues Related Tips
jim behr
Hibbing, Minnesota
Good Sam RV Club
Posted: 11/08/09 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Being fairly new to diesels, I have 30k on my 2005 superduty 6.0, is it necessary to add additives to the fuel EVERY time I fill up in order to keep the injectors from clogging? It seems as though one would have to carry a case of it along if you fill up a couple of times or more a day.
Jim
2 polar bears
2005 Ford 250 powerstroke
2007 Jayco Eagle 29.9 rls
TEXAS
Centerville Tx
Posted: 11/08/09 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
As long as you have fresh fuel going through them. You do not need to add anything. If it is going to be stored for some time. They do have products that will keep algee and other nasty things. From growing in your fuel tanks. You might want to check with the engine OEM about any problems ewith low sulphur fuel. The shop that rebuilds my pumps and injectors. Has told me of problems with older systems and low sulphur diesel.
jefff929
Pacific wonderland, wet side
Posted: 11/08/09 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
on a 6.0 I wouldn't add anything.
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 24.5' Prowler 5er
Diesel Bombers
My Baby
Another NWBomber
Raften
Northern Calfornia
Posted: 11/08/09 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Add 5 to 10 percent biodiesel for lubrication.
gunny357
North Carolina
Posted: 11/08/09 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
You shouldn't have to add anything except more fuel, they are thirsty.
btd35
Spokane, WA
Posted: 11/08/09 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
I run an additive to mine when I'm pulling, and every other tank when not. 90,000 miles ago, the water jacket cracked on my Dodge, a defect in the Cummins block. I had the engine rebuilt with a new block and my parts, new rings, bearings gaskets, etc. The mechanic asked me if I ran an additive in my fuel, and I told him what I did. The engine had 85,000 miles on it, and he said it looked like new inside! No wear on anything, and nearly spotless. I continued the same treatment since then, and now have another 100,000 miles on the rebuild and going strong.
If your manufacturer allows it, try putting bio diesel in and run a couple tanks. The first tank for me lost milage by about 3 mpg do to the lower octane. The second tank the mpg came back up. Then I put a tank of regular diesel in, and I gained 2 mpg over that! Bio diesel is a great injector cleaner.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
Dave H M
IL
Posted: 11/08/09 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
that motor will rattle happily along without snake oil.
However, add what you finally decide on and it will make you feel at ease and that is what counts.
Vulcanmars
Naples, FL
Good Sam RV Club
Posted: 11/08/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I would run motorcraft cetane booster. The 6.0 likes a 45 or better rating. It will make your injector tips, EGR valve, and turbo live longer.
Note: Use the recomended dose, more will not be better.
Mars
06 Rage'n FA3005
04 V10 F250 SDCC 4X4
Raften
Northern Calfornia
Posted: 11/08/09 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
I am about to take off on a cross country trip and for the first time in 40,000 miles I will have to put diesel in my Dodge instead of B100 biodiesel. My plan is to add Marvel Mystery Oil each fill up.
jauguston
Bellingham, WA
Posted: 11/08/09 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
Raften,
I'm curious --- why??
Where in the engine operating instructions did it say to use anything other than #2 diesel fuel.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
 > diesel injectors
