RV.Net Open Roads Forum: Dinghy Towing: Roadmaster Falcon 5250 towbar
Search only in Dinghy Towing
 > Roadmaster Falcon 5250 towbar
Dinghy Towing Related Tips
lwasouth
Good Sam RV Club
Posted: 11/09/09 08:36am Link  |  Quote  |  Print  |  Notify Moderator
I would like input from anyone using this towbar as to good or problems to expect
fishboat1
southern ca, SW Riverside County
Posted: 11/09/09 09:52am Link  |  Quote  |  Print  |  Notify Moderator
I have been using a Falcon 5250 for over seven years and so far no problems.
Mike H
2007 Allegro Bay 34XB FRED
2002 Dodge Dakota 4 wheel drive Toad 4.7 v8
Four Winns fishing boat
JAXFL
Jacksonville, Florida, USA
Posted: 11/09/09 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Roadmaster Falcon 2 ALL TERRAIN. I have the Roadmaster Falcon 2 and sometimes it is hard to disconnect on uneven ground.
bobsinn
Key Largo, Florida,USA
Good Sam RV Club
Posted: 11/09/09 10:09am Link  |  Quote  |  Print  |  Notify Moderator
We have a 5250 and after 20K miles towing the only negative is it can be hard to unhook if not on level ground.
2001 Itasca Sundancer 27P
2000 Honda Civic
Fishinghat
Western Washington, USA
Posted: 11/09/09 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
We previously used the Falcon and found disconnecting sometimes difficult. We now use the Blue Ox Aventa II which works well.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
SPRING STREET
LOUISVILLE KY.
Posted: 11/09/09 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
I also have the 5250 and overall very good towbar but i must agree if MH and tow are'nt level it can be a problem to get the pins out.. Keep everything clean and lubed and it will make a difference !
2000 37 1/2' MOUNTAIN AIRE BY NEWMAR,TOAD 2009 HHR, License plate "TOWED" > RoadMaster Tow Bar and Base Plates.
brobox
Sunny SW. Florida
Posted: 11/10/09 06:46am Link  |  Quote  |  Print  |  Notify Moderator
I did not like the large, heavy bracket of my Roadmaster that had to be stored when not towing. I also switched to Blue Ox, much easier to connect and disconnect and nothing to store but 2 small couplings.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
bsinmich
Holland, MI
Good Sam RV Club
Posted: 11/10/09 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
We have used ours for 9 years and the only thing I would say is the unhooking when unlevel or on a grade. We carry a rubber mallet in the rear compartment and 1 light swat releases it a lot easier than using the palm of my hand. I don't consider that much of a problem. I have many hammers.
2003 Newmar Mountain Aire, Workhorse W22, & 2002 PT Cruiser w/Remco lube pump, Falcon 5250, & US Gear Unified Tow Brake
