RV.Net Open Roads Forum: Tech Issues: Battery capacity and amp hours?
 > Battery capacity and amp hours?
Tech Issues Related Tips
wild bill
Mira Loma, Ca. USA
Posted: 11/09/09 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
I am a little confused about how to figure total battery amp hours.
I have 6 six volt batteries wired to make 12 volts. The batteries have an amp hour rating of 220 hours each. Do I multiply 6x220 to get
1320 amp hours or since I have 3 banks of 2 6v batteries wired to make 12v is my amp hours realy 660?
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
2oldman
Indio CA
Posted: 11/09/09 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
660. You have 1330 at 6v, but 1/2 that at 12v. It's a watts thing.
RJsfishin
Winston Or.
Posted: 11/09/09 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
But only 330 usuable amp hrs, if you hold the 50% discharge rate to prolong battery longivity.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
wolfe10
Posted: 11/09/09 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
All correct answers.
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
wild bill
Mira Loma, Ca. USA
Posted: 11/09/09 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick replies.
pianotuna
Regina, SK, Canada
Good Sam RV Club
Posted: 11/09/09 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi wild bill,
I hope your 6 six volt batteries are wired in a balanced manner. See method #3 here:
correctly interconnecting multiple batteries
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
Wherever I happen to park
Posted: 11/10/09 09:03am Link  |  Quote  |  Print  |  Notify Moderator
When you wire batteries voltage So six+six =2 volts since they are 220 amp hoed to be identical) you have 220 amp hours.
I am fond of saying "There are no six volt batteries in RVs" even if you and I both have a pair of them.. The reason I say this is the pair of sixes, in series becomes a volt battery for all technical discussions S
Now, if you wire batteries in parallel then you amp hours.. So a pair of G-27's at say 100 amp hours each (These are 12 volt batteries) = 200 AH.
NOTE that when discussing amp hours.. The voltage is not a factor.. That comes in wish to calcualte WATT HOURS. Which we almost never do.
The other thing to remember is you can safely use 1/2 the capacity. You can use more.. but it will shorten time between to the battery store
