vincent44cal
home
Good Sam RV Club
the white plastic door on my motorhome has turned yellow. How do I make it white again?
Fizz
Ottawa, Canada
KRYLON
dervatl
Smyrna GA
Good Sam RV Club
I've had that problem on everything plastic on the outside. Fridge vent cover, door holder, outside light, etc. Here's something that works well and is cheap. The best way is to remove the item from the motorhome. It makes for a clean job that will look good. I usually wipe it down with lacquer thinner to remove anything on it. It will also remove some of the "yellow" too, but don't leave the thinner on it too long. I then spray it with Krylon paint made for plastic. You can find this in any hardware store or WalMart. Make sure it's the one for plastic or it will not adhere properly. Usually two or three coats completely renews the appearance. Let it dry several hours or more. Reinstall.
If the item is too hard to remove, use masking tape around it. Make sure there is plenty all the way around or you will end up painting your motorhome wall too. This method has held up well for me.
Rolling Condo
South Carolina
Krylon Fusion is your best bet outside of replacing. The paint holds up very well.
'90 GMC R2500 7.4L
'90 Avion 34V
Cummins Onan P4300ie
Reese Dual Cam HP
Prodigy
96Bounder30E
Orange County, CA
Good Sam RV Club
I sprayed my yellowing refer access door with "oil eater" and the yellowing just ran off leaving the door white again........
w6pea
Lost in the Smog of Mexifornia
What is "oil eater"?
Remember "Without Truckers America Stops"
It's too late to save your shoes..so roll up your pant legs
"When all else fails..Amateur Radio"
I need some more Coffee&Old Bushmills
Semper Fi
bradyk
Calgary, Alberta
Googled it and looks interesting.
Check out their website here.
http://www.oileater.com/CleanerDegreaser.html
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Champion 4000W Generator
Ken & Sandra
Shadow Cat,Yugi Dog, Jet Dog
16 Foot Renken Fishing boat
Gene&Ginny
North Kingstown, RI
Awesome from the local Dollar Store and bleach. I usually use it once a year in the spring and the white trim and plastic stuff (like the 110v outlet cover) stay white all season.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
happycampersweare
lincoln park michigan
Good Sam RV Club
Gene&Ginny wrote: Awesome from the local Dollar Store and bleach. I usually use it once a year in the spring and the white trim and plastic stuff (like the 110v outlet cover) stay white all season. I second the Awesome,works great and the price is right
03 dodge 2500 5.9L diesel
2008 35ft.Denali 31sbbs-m5
Rbrunson
Tangent, Or.
Another vote for Oil Eater. I get it at my local CostCo store.
Dodge Quad Cab Cummins turbo diesel 3500 4x4 5-speed. U.S. Gear exhaust brake, 1500w inverter, 115v onboard air compressor.
'07 Mobile Suites 36 SB3 #3424
