RV.Net Open Roads Forum: Dinghy Towing: Wrangler Tow
Search only in Dinghy Towing
 > Wrangler Tow
Dinghy Towing Related Tips
2more2go
Idaho
Good Sam RV Club
Posted: 11/10/09 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
We're looking to pull a 2009 Jeep Wrangler (2 door, manual tranny) behind a 2007 Winnebago 29B Outlook. Need suggestions as to best hitch setups/systems....or setups/systems to avoid. Thanks for any input.
BarneyS
S.E. Lower Michigan
Good Sam RV Club
Posted: 11/10/09 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Dinghy Towing forum from Towing.
donee
Simi Valley, Ca. 93063
Good Sam RV Club
Posted: 11/11/09 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, we had a Road Master system installed on our 09 Wrangler 4 door and are very happy with it.
We re pulling the Jeep with a 05 29' Monach Class C.
Hope this helps.
donnie & Linda
05 Monaco Esquire 29PBD
09 Jeep Wrangler Sahara Unlimited.
KC6CME
RVJimofOregon
Central Oregon Coast
Good Sam RV Club
Posted: 11/11/09 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
I pull a 2006 behind a 36 ft Discovery with no problem. I bet if you do a search of Jeep or Wrangler you will find more information that you need.
RV Jim
Jim & Joyce
2000 Fleetwood Discovery 36T Diesel Pusher
2006 Jeep Wrangler Unlimited
2007 Prius
mowermech
Billings, MT
Posted: 11/11/09 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use a simple A-frame towbar made by Valley (or maybe Reese, I'm not sure). It only cost $145 when I bought it years ago, and it does the job just fine. A similar one is available from Harbor Freight for under $70.
If you desire something more "convenient" you can spend what to me is a ridiculous amount of money for a fancy telescoping towbar that when all is said and done does exactly the same thing as the less expensive ones.
The choice is yours.
For a braking system the only one I would consider is the Ready Brute or Ready Brake. Simple, easy to install, no heavy actuator unit to carry around, and relatively inexpensive.
Again, your choice.
Good luck.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, 5 speed, 4.10 LS diff., Jacobs Rambrake, 274,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '08 Subaru Outback
Towed: '06 Jeep Rubicon Unlimited/Load Trail 16' flatbed
travisc
Pacific NW
Posted: 11/12/09 03:11am Link  |  Quote  |  Print  |  Notify Moderator
You can go many ways with this- But one nice thing I have seen is this plug and play wiring kit from cooltech- http://www.cooltechllc.com/jeep/jk_tow_deluxe_kit.shtml
they have a few options= but this makes it very easy.
I tow a 2006 LWB TJ with my 24V Access with out any issues using Roadmaster Brackets and the Evenbrake system- for washington state law requires anything over 3K have supplemental brakes with a breakaway switch. For the towbar I used a falcon 2 I picked up off of craigslist for $250, Wrangler brackets $300 off of ebay, and the evenbrake was $900 new, I forget where.
Hope that helps
Winnebago Access 24V
wilanddij
CA Desert
Good Sam RV Club
Posted: 11/12/09 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Check out this link billarf wrangler tow. Written for 2007 JK, but should translate well to 2009 JK.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
 > Wrangler Tow
