MichDoc
Michigan
I just had my Jeep Wrangler fitted out for towing behind a motor home, and I was wondering how people protect and stow the wiring harness when they aren't towing the dingy. I considered wrapping it in plastic and taping it, and then tucking it behind the grill, but thought that there may be much better ideas out there. I don't want to just leave it out to the mercy of the snow, salt, and road debris. Any thoughts?
enblethen
Moses Lake, WA USA
Good Sam RV Club
I have a short end on my toad. I use a five foot ectension cable to go along the path of the towbar. I can then remove all of the exposed cable.
Bud
Suzuki XL7 pushing Pace Arrow
othertonka
Stockton, CA
Good Sam RV Club
I set up my toad wiring with this coiled cord. You install a plug on the front of the toad and a plug on the rear of the MH and then just plug the cord in when you tow. Unplug when you disconnect and stow it in a compartment.
Coiled Cord
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Popsie
Livingston, TX, USA
I have a coiled cord attached to the tow bar. When I remove the toad, I fold in the tow bar, secure it with a locking pin, and put a cover over the whole assembly which includes the coiled up cord.
Picture of cover.
robatthelake
Vancouver Island
I just coil it up and stuff it into a Zip lock Bag! Stows under the hood!
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
othertonka wrote: I set up my toad wiring with this coiled cord. You install a plug on the front of the toad and a plug on the rear of the MH and then just plug the cord in when you tow. Unplug when you disconnect and stow it in a compartment.
Coiled Cord
That's what I do also.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
Not a Clue
Southern Ca
Good Sam RV Club
Popsie wrote: I have a coiled cord attached to the tow bar. When I remove the toad, I fold in the tow bar, secure it with a locking pin, and put a cover over the whole assembly which includes the coiled up cord.
Picture of cover.
X2
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
MichDoc
Michigan
Thanks folks. The dealer that installed my tow bar just ran a five foot length of wiring harness that plugs into the motorhome, but no plug on the toad end. I guess this winter I'll just wrap the wiring in plastic and tuck it under the hood to keep the crud out until I can redo it next spring. Thanks for the ideas.
carp65
Sioux Falls, SD
Good Sam RV Club
We remove ours and put it in the car when not towing. Works for us!
MichDoc
Michigan
carp65 wrote: We remove ours and put it in the car when not towing. Works for us!
If mine was removable, I'm sure I would do the same thing, but mine doesn't unplug. It's hard wired into the toad, and then plugs into the MH when needed. When not being towed, I have about 6' of wire, plus the connector, that has to be rolled up and stashed somewhere.
