Geewizard
Alaska, USA
BlueStilly wrote: I just don't like the idea of drilling holes in a brand new truck  .
My TorkLifts didn't require any drilling when installed....if that's what you're referring to?
Tundra Double Cab
Outfitter Apex 8
Full Size Rig Pic
Arctic Circle, Alaska
Marion Creek, Alaska
BlueStilly
Stanwood, Washington
Geewizard wrote: BlueStilly wrote: I just don't like the idea of drilling holes in a brand new truck  .
No, I was talking about having to drill a hole or holes for the HappiJacks. I also have Torklift on my truck and think they are a great product.........
SoCalDesertRider
SanDiego, CA, USA
BlueStilly wrote: I just don't like the idea of drilling holes in a brand new truck  . I've never owned a truck in my life that the bed didn't look like swiss cheese by the time I was done with it. All my trucks get used as real trucks and get all sorts of stuff mounted on them for whatever purpose I need. Drilling holes and welding on my trucks is just par for the course for me.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
5Alive
Salt Lake City
Although I don't care for any product Happijac has ever made, I'd think with a light camper on a light truck it would be just fine. Plus have the added benefit of having nothing extra low on the truck to get in the way of your offroad excursions.
1995 Weekender 1010 Ext
2005 Dodge Ram 3500 DRW 4X4 CTD Regular cab
Hoka Hey
Casper, WY USA
I use torqlift fronts and the bumper buttons on the rear for my Apex 8 on a Dodge 2500. The rear bumper is aftermarket and is easily up to the task. Occasionally I have to bend the tabs that attach the fastguns to the buttons. They seem to bend easily and become hard to remove/reinstall.
stevenal
Newport, OR, USA
Make sure you get the HJ bumper reinforcing brackets if you go that way.
'99 Bigfoot 1500
with low loss control on the Fantastic, Dino board on the Dometic.
Torklifts and Fastguns
'04 F350 V10 Crew SRW SB 4X4 6 speed
with tow hook replacement, dual rate charging, Line-X, Timbrens.
My Blue Heaven
Missouri
I started with HJ and ended with TorqueLifts, which I wish I'd bought in the first place. My vote is for the latter. (and I wish I hadn't drilled those holes for the HJ's).
formerly avionguy
2001 F350 Lariat CC 4WD 7.3 PSD dually, chipped, 4" SS exhaust, 350 hp, Rancho 9000's, front receiver
2009 Arctic Fox 990S, storm windows, Cummins/Onan, FastGuns, Torklifts
BradW
Flat Rock, Alabama
stevenal wrote: Make sure you get the HJ bumper reinforcing brackets if you go that way.
Ditto. They cost about $25 and only take 30 minutes to install with simple tools.
I've been using HJ front & rear tiedowns for 14 years and never had the first problem with them.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
narcodog
Georgia
After many years of 4 wheelin I have found that anytime pipes come straight off the back you will back into a bank or rock and either fill them up with dirt or bend at which time you will have to replace them. Also if you get into water and you have a hiccup water will more likely get into your mufflers quicker.
