RV.Net Open Roads Forum: General RVing Issues: Removing Graphics-Any Experences?
 > Removing Graphics-Any Experences?
General RVing Issues Related Tips
forwardfiver
Long Beach, CA
Good Sam RV Club
Posted: 11/11/09 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Hi all, DW and I recently purchased a 2005 Fleetwood Widerness Adavantage AX6 5er. The interior is like new but the outside has some slight oxidation and the graphics are peeling up. Has ayone removed their graphics and if so, how did you do it and how did it come out? Any info would be appreciated!!
Rich
2005 Fleetwood Wilderness Advantage 365BSQS
2000 Ford F-550 CC Dually 7.3L TD Banks Power Pack 4:88 gears
sonicsix
Jemison, AL
Good Sam RV Club
Posted: 11/11/09 11:33am Link  |  Quote  |  Print  |  Notify Moderator
We removed the large graphic from the front of our travel trailer because it was peeling and looked unsightly. We just used a safety razor blade and slowly scraped it off, tiny piece by tiny piece. We took great care not to scratch the fiberglass. The remaining glue residue was removed using Goo-Gone.
It took about an hour to remove the whole thing. The only thing noticeable is you can see the outline where the graphic was since that area had never been exposed to the sun. Over time, it will weather and look like the rest of the camper.
Why We RV | Our Lighthearted Blog | Our Big List of Mods | The RVer's Library
skipnchar
Topeka Kansas USA
Posted: 11/11/09 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I WATCHED a guy using a hair dryer to remove about 3/4 of the graphics from a brand new Eagle travel trailer a couple of years ago. With the new trailer it was pretty easy and his purpose was just to clean it up. With older graphics where they've turned brittle it would probably be a lot harder and will also probably leave some shadow of the images behind when finished.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Padlin
W. Ma.
Posted: 11/11/09 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
On cars, yes, heat (hair drier or heat lamp) and a plastic scraper/squeegee.
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
Beacher
Long Beach, CA
Posted: 11/11/09 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I have seen entire swoosh graphics come off within seconds from motorhomes at self-serve powerwash car wash places. However, they did it un-intentionally!! The heat and pressure of the water is no match for the giant vinyl stickers.
patnchris
Gurnee, Il. USA
Posted: 11/11/09 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
You need to GENTLY heat the old graphics and peel them. Then remove any remaining glue. Some of the Orange cleaners are good for this. Keep in mind that the finish under the graphics has not been exposed to the sun and weather. There will be a definate difference where the graphic has been removed. It doesn't matter whether it is gelcoated fiberglass or filon, the difference will be there. There is no amount of waxing or polishing that can make it invisible. The good thing is that after a summer of exposer to the sun and weather, the difference will disappear on it's own.
Patrick and Christine
and Maggie May, the cocker spaniel
1995 Damon Ultrasport 3470
Rallies Attended "21"
4*phun*2
Canada
Posted: 11/11/09 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
A hot air gun and some patience and they will peel right off.
Glenn & Karen
'06 F350 4X4 Lariat CC LB DRW (nice hips)
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
dalebear
home
Posted: 11/11/09 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Go to a auto paint supply and they have a rubber wheel that will take the graphics off and not damage the finish. I used it to take old ones off my RV and it took most of the glue off too. Just make sure you have it at the right speed or it will burn the surface.
