RV.Net Open Roads Forum: Dinghy Towing: Towing an older Ranger
Search only in Dinghy Towing
 > Towing an older Ranger
Dinghy Towing Related Tips
TexasPhillip
Lewisville, TX
Posted: 11/11/09 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Okay, I am looking to buy an older Ford Ranger pickup to pull 4 down behind my motorhome. I can't seem to find information on which of these can be towed 4 down. Some of the Rangers I have looked at don't have the owners manual anymore.
Can any standard transmission older PU like this be towed 4 down? I have seen a list of newer cars and trucks that can and can't be towed 4 down, but I have not found a list for older (mid 90's) cars and trucks.
Any help pointing me in the right direction would be appreciated.
thanks,
Phillip
dicknellen
Northern Nevada, USA
Posted: 11/11/09 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Per the 94 guide
Ranger 2wd manual trans yes, auto trans No
Ranger 4X4 manual trans yes, auto trans Yes with manual transfer case
Per the4 96 guide
Ranger 4X4 manual trans Yes with manual transfer case
Ranger 4X4 auto trans Yes with manual transfer case
AliCat
Millsboro, De.
Posted: 11/11/09 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I towed a 1996 Mazda B3000 pickup 15,000 miles. It had a manual transmission. Had no problems. The Mazda B Series and the Ford Rangers are the same except for trim. Good luck.
Art
2005 Winnebago Voyage 33V (Workhorse)
Garmin 2620 Street Pilot
2008 Honda CR-V EX-L
Blue Ox Aventa II, Apollo Brake
Protect-A-Tow
rv2go
Fulltime between Knoxville, TN and the coast.
Good Sam RV Club
Posted: 11/11/09 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would suggest that you take a look at the Remco site and look at the model year that you plan on towing.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
TexasPhillip
Lewisville, TX
Posted: 11/12/09 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies! The search for a toad continues.
Phillip
tatest
Oklahoma
Posted: 11/13/09 12:44am Link  |  Quote  |  Print  |  Notify Moderator
Depends on how old the older Ranger, as they go back to the '80s, using a number of different manual transmissions.
My '92 was officially not towable, but it was actually towable because of the particular manual transmission that was installed. My '01 is officially towable, because Ford by then had stopped using the not-towable manual transmission, so there was no doubt which one was installed.
Basically, the Mazda-derived M5OD transmission is towable if you follow the guidelines, 200 miles under 55 mph. The Mitsubishi-derived M5OD transmission is not approved, by either Ford or Mitsubishi, for recreational towing.
Earlier 3-speeds and 4-speed overdrives, I have no information.
Automatic transmissions, none towable since the Ranger was introduced, unless the transfer case in a 4x4 has a neutral that makes the truck towable.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
kosjohn
Lubbock, Texas
Posted: 11/13/09 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
TexasPhillip... i have towed a 02 ford ranger p/u 4 down behind my motorhome. i had a remco driveshaft dicconnect installed and it worked great..Just 2 weeks ago i traded the p/u in for a jeep liberty, but still have the driveshaft disconnect for the ford.If interested email me at.. flat-top@yahoo.com Have a nice day....kosjohn
