RV.Net Open Roads Forum: Travel Trailers: Basic TT Towing Question?
 > Basic TT Towing Question?
Travel Trailers Related Tips
EKS
San Clemente Ca. USA
Posted: 11/14/09 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Planning to tow a 27' TT one way
of 300 mi., borrowing a 1/2 ton 2000
Surburban, which has a tow rating
of 7500, TT may be 4500 empty,
I've never towed anything more than
a jet ski, is there anything that
I need to know or pay attention
to, or am I getting in over my
head for a novice?
thanks for your time and info
EKS
downtheroad
Puget Sound
Posted: 11/14/09 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Take it easy
Make wide turns
Practice backing up (if you can't back it up you shouldn't be pulling it forward).
Good luck with it.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/14/09 11:36am Link  |  Quote  |  Print  |  Notify Moderator
How are you going to operate the electric brakes on TT if equipped?
Do you have some sort of mirror extensions?
Bud
Suzuki XL7 pushing Pace Arrow
b_salgado
Salisbury ,NC,USA
Posted: 11/14/09 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Weight distribution hitch
Brake controller
Mirrors
Lock out OD if equipped.
Allow room to make your turns and stops
The truck and trailer will behave differently than when you are not towing. You are heavier, longer, and wider.
04 Lariat Supercrew 4x4,5.4,3.73, Edge tuner, flowmaster duals
06 Trail Bay 31BH, nicely optioned
Equal-i-zer
Prodigy
Follow vehicle, 05 KIA Sorento EX for the golden retrievers.
tunerdude
Midlothian, Virginia
Posted: 11/14/09 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Don't carry more water in the TT's tanks than you have to. Stay to the right. If you have to change lanes, prepare way in advance, making sure you have ample room to move your entire rig over. Carefully adjust your brake controller so that the trailer's brakes engage very slightly before the truck's brakes. Carefully adjust the brake controller so that the TT's brakes don't grab hard. Before starting out, check tire pressure all around. After 50 miles, stop and check the security of the hitch and all of your connections and trailer lights. The weight you tow makes all the difference. Have a successful and safe journey!!
Chuck&Gail
In the Colorado Mountains
Posted: 11/14/09 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Brake controller
Mirrors
Above looks like a good list AS LONG AS Weight Distribution Hitch has built in sway control. If it does not, add sway control to the list, or, be sure you keep speed ALWAYS below about 40 mph.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
RRUGG
Newaygo, MI,USA
Good Sam RV Club
Posted: 11/14/09 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Every last one of us was a novice when we started towing. You'll be fine.
RRUGG
2008 Dodge 2500 QC 4x4 SB Cummins 6 speed auto 3.73
1997 Holiday Rambler 29FK travel trailer
2009 Hyundai GLS
Bob & Grace professional retirees
Good Sam life members
Camped in 49 states. Missing Hawaii.
DanKirk
NorCal
Good Sam RV Club
Posted: 11/14/09 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Watch your mirrors. Take it slow.
2008 Wilderness 240RKS
2008 Dodge Ram 2500 Quad Cab Cummins Turbo Diesel
coolbreeze01
Redding, Ca
Posted: 11/14/09 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
I'd check the TT tires, bearings, brakes, and spare. Hitch, safety chains, frame, and lights. Have the necessary tools to change tires, and don't forget duct tape. Have a safe trip.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
Tee Jay
Port Angeles, WA
Posted: 11/14/09 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
If you borrow a truck, does it have a brake controller installed? And does it have a 7-pin connection to plug the trailer into? If yes to both, you can make it work. If no, return to drawing board.
