RV.Net Open Roads Forum: New beds in the "B"
Open Roads Forum  >  Class B - Camping Van Conversions  >  DIY
 > New beds in the "B"
Class B - Camping Van Conversions Related Tips
bobwalter
Treasure Coast of Florida
Posted: 11/14/09 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
We recently purchased a 1997 Coach House with the electric couch/bed in the back. The couch was very comfortable for sitting. Shortly after getting it we went on an overnight shakedown. Everything worked well and we think we will love traveling in it. All was good until it was time for bed. We extended the couch and made the bed. We wnt to bed and all was good until the first trip to the bathroom. I was in the back and had to crawl over my DW. As many of you have probably found out, the older you get the more night time trips are needed. We discovered that the sleeping arrangements weren't going to work. I just am not good at climbing over.
I decided to remove the electric couch (which I now need to sell) and install two beds on each side in it's place. I removed all the wheel well covering, and the water heater covering. I lost two drawers on each side but was able to install one on each side under the beds. The net loss was one drawer on each side but I have a plan to gain four more drawers in another location. (I will document when I do that project.)
I framed out the rear with 1X3 lumber and I was able to use some of the removed material to keep the wood color the same as the rest of the coach. I have as much under bed storage with the new configuration as I did with the couch.
I ordered foam from the internet and made matresses/cushions. I tried my hand at upholstering (first time ever) (I learned to sew) and I think they came out well. I, as well as my DW are very satisfied with the outcome.
I started with a standard electric couch/bed.
Framed out beds.
You can see the drawers under the beds.
Upholstery completed. Project complete. Now we can sleep. Also comfortable seating.
Still a lot of storage underneath and accessible from the back door.
I am happy with the results and it looks factory made. It will make our "B" much more comfortable for the two of us.
Bob .....N8DUV
in sunny Sebastian, Florida
NW22
Edmonton
Posted: 11/14/09 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice job.
radio man 7.262
terre haute in u.s.a.
Posted: 11/14/09 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Looks very,very good. Bob
Goldencrazy
madison wi
Good Sam RV Club
Posted: 11/14/09 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent. I like the idea of twin beds as well.
booster
Minnesota
Posted: 11/14/09 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice job! I am in the process of doing a similar thing to our 07 Roadtrek 190P. Our power couch made a "C" shaped bed, and wasn't all that uncomfortable, but it ate up way too much of the storage area. I am shooting for a totally clear area from the rear doors to the bolster cabinets (where the center of the bed will end). The bolster covers will hinge up, like the stock setup, and the front 1/2 of the bed will do the same, for access to the storage area under the bed.
It looks like your van is pretty straight across the back, by the doors, while our Chevy is quite curved. We want to use the doors for the backrest (looks like you did too), so it appears the back of the bed will also need to curve. Makes the reinforcing needed to go without a center leg a bit tougher. It looks like you used an angle iron and trim board? We have a pretty low clearance in that area, so I am going to try to move the support structure to above the platform, if possible. How much height do you have under the trim board in the rear?
I hope ours turns out as nice as yours did!
juliev
SE Minnesota
Posted: 11/14/09 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
You did a great job!
Julie
_____________________________________________________________________
A good traveler has no fixed plans, and is not intent on arriving. ~ Lao Tzu
bobwalter
Posted: 11/14/09 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for the comments.
Booster,
Mine is pretty straight across the back. Be careful of the headroom while sitting against the back doors. Mine curves in towards the front. I used 1X3 for all the framing except across the back. There I used a 2X4 on edge and added a 1 1/4 aluminum angle. I don't think the angle was necessary, but I had it. I haven't measured it but I have somewhere around 18" under the back. I can measure if you need it. My bed platforms do not hinge. They are fastened down with just a couple of screws for service access. (Water heater, water pump, etc) I can access (from the back)approx. 5 feet on both sides and 27" in the center. Room for folding chairs, chaise lounge, jack, tools, screen room, and more. If you need other pictures or measurements, let me know.
gmctoyman
Lake Livingston, Texas
Posted: 11/14/09 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Nice work ! The power sofa in my LTV has crapped out again, as soon as I get time it's coming OUT !
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
booster
Minnesota
Posted: 11/14/09 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
At 18", you are a bunch higher, and lots more space, than we have. Wish we had that much height. We were at about 12" with the power couch, and will get to about 14 1/4 with the platform. Headroom isn't much of an issue for us, as it is pretty flat in the ceiling above the seating area. We will have about 4' wide by just under 5' of clear area underneath.
Coalminer UG
Grande Cache Alberta
Good Sam RV Club
Posted: 11/14/09 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Nice Job.
Ches and Marie
