RV.Net Open Roads Forum: Truck Campers: TC rear deck pics
 > TC rear deck pics
BIG RIG GUY
Milton Ontario
Posted: 05/12/10 08:13am Link  |  Print  |  Notify Moderator
yea thats great, now I gotta build a porch, wow all of them look real sweet. Really good pics giving me lots of ideas, thanks for posting
There is a method to the madness, disturb the method and the madness begins.
HioSSilver
Winchester, VA
Posted: 05/12/10 01:25pm Link  |  Print  |  Notify Moderator
Jumbo Jet wrote:
HioSSilver wrote:
I fastened it to the middle bolt of the camper jacks... yes it's heavy.. I may have overbuilt it...lol. But it's also a hitch extension, you can it if you look close. I have since added my camper step to it and painted it and stained the boards and added reflecters.
Have you ever loaded the Mini that is sitting in front of your truck on that deck?
Not my mini. I do paintwork mostly out of the shop in the background and that's a mini I painted. I am planning on putting my polaris rzr on the porch
btggraphix
Golden, CO
Posted: 05/12/10 02:04pm Link  |  Print  |  Notify Moderator
How about a different approach?
one deck, for the rear:
or side:
If the goal is to not have to take a trailer for the extra stuff, it won't help. But it's a nice way to go if you need to bring a trailer anyway....and it's a bigger deck than you can attach to the camper......
2006 LanceMax 1191 - loaded and well-used
2005 C4500/Kodiak 4x4, GVWR 17,500
RICKIM
The Ocean State
Posted: 05/12/10 07:29pm Link  |  Print  |  Notify Moderator
Heres mine, I made it out of 1"x1"x1/4" aluminum, with 2, 2"x2"x1/4" runners for stability.
The deck is 3/4"x6" PVC planking
Heres the bottom folded up for travel....the step is removable.
There were existing brackets on the bottom of the bumper that I used as hinges with 5/16" stainless eye-bolts.
Then I drilled the holes in the supports for the deck support cables which are 1/4" coated cable.
Show us what you came up with when your done with yours. Good Luck
Rick
2007 AF 1140, 2.5KW Onan, 200 Watts of solar, Trimetric, 2 Lifeline GPL-31T's, 1000w inverter, rear deck, Turbo/Maxx fans.
2007 Dodge Ram Quad, DRW, 6.7L-CTD, EB, Air lifts, Hellwig,
Stable Loads, Rancho 9000's, Tork-lifts and fast-guns.
GTO66
Posted: 05/13/10 08:03am Link  |  Print  |  Notify Moderator
Hi all, I've been following this thread as I will be building a rear deck. My question is who sells the bracket for the swing down rear step? I've checked a few rv supply stores without any luck.............Thanks
RICKIM
The Ocean State
Posted: 05/13/10 08:35am Link  |  Print  |  Notify Moderator
I made a deck identical to mine for my sisters TC and had to use
2" x 3/16" or 1/4" wall (I don't remember the thickness) aluminum u-
channel, as her TC didn't have brackets either. I cut it up into
five 3" lengths and riveted it on with some 3/16" blind rivets.
Works great. Good Luck Rick
can'twaittil2016
SoCal
Posted: 05/13/10 09:29am Link  |  Print  |  Notify Moderator
Ok, this is the first time I've tried to add a picture and I'm not sure if it will work. If it does, you will see a pic of my porch. The box keeps my genny safe and out of the elements. If you look closely you can see the homemade "Gen-turi" style exhaust system I made. This set-up has about 5000 mi on it and it works well for me. Hope you like it. Happy camping!
GTO66
Posted: 05/13/10 10:06am Link  |  Print  |  Notify Moderator
Rickim..........Thanks for the idea if I can't find orignal brackets I may make my own..All thoughts appreciated
fotosleo
Posted: 05/13/10 10:24am Link  |  Print  |  Notify Moderator
Here's your pic...
hard3
southern Illinois
Posted: 05/13/10 11:57am Link  |  Print  |  Notify Moderator
Here is a picture of one I built , and have since sold camper.
 > TC rear deck pics
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
