RV.Net Open Roads Forum: Truck Campers: Made me some superhitch mud flaps
 > Made me some superhitch mud flaps
Adub
Twin Falls
Posted: 09/14/10 01:07pm Link  |  Print  |  Notify Moderator
Looking for some easy to install flaps while pulling my boat,
It did not look like the ones that go on the ball mount would work with a supertruss.
So I decided to make my own, they came out nice, easy to put on and take off.
I used two 7' receiver tube that slides over the torklifts, some 1 1/2 angle iron
and some 1"flat strap, Found some heavy belting and cut my flaps to size.
cost me less than $50!
rkortes
Citrus Heighs, CA
Posted: 09/14/10 01:16pm Link  |  Print  |  Notify Moderator
Nicely done!!
Truck - 2005 GMC 3500 SRW Duramax/Ali
Camper - 2006 Arctic Fox 990
The Journey Is The Destination!
Darryl&Rita
Grande Prairie, Alberta
Posted: 09/14/10 05:26pm Link  |  Print  |  Notify Moderator
Might be just the way the truck is parked, but if it was on level ground, I'd shorten the rubber a hair. If the rubber is dragging on the ground, it can kick up nearly as much debris as the tires. I've made several versions, for several vehicles, and always mount mine with 2 1/2-3" of clearance when hitched up.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
Tops
Washington
Posted: 09/14/10 05:29pm Link  |  Print  |  Notify Moderator
That looks great! I really like that idea!!! Good job!!!
2008 Chevy 2500HD D/A SB 6" lift
35" load E tires on 20" wheels
Stable Loads / Air Bags
Hellwig rear Sway Bar
Super Springs
2011 Arctic Fox 811 camper loaded!
SoCalDesertRider
SanDiego, CA, USA
Posted: 09/14/10 01:56pm Link  |  Print  |  Notify Moderator
Looks good and should work great. I did something similar with my own rear tie down bar and a pair of truck mud flaps. Works great.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
BradW
Flat Rock, Alabama
Posted: 09/14/10 02:13pm Link  |  Print  |  Notify Moderator
Nice work. Added to the TCU sticky.
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos........Visit the RV.net Blogs
Adub
Twin Falls
Posted: 09/15/10 09:30am Link  |  Print  |  Notify Moderator
My exhaust does kind of blow against the flap but it not very hot with the diesel,
I did the same thing on my old Duramax (now I have a F350) but on the GM I had to put a turn down tip on my exhaust because it was blowing right at the flap.
I got the belting from a machine shop in my area that sells all kinds of stuff.
Its 2ply about 3/8 thick.
You could also get some flaps from Nampa or whatever auto parts store and cut em down
Cannot really see the exhaust in the pic but its behind the right flap and comes out at an angle that it blows by the flap not into it.
Auxillary
Delaware
Posted: 09/15/10 08:40am Link  |  Print  |  Notify Moderator
Very nicely done. I'm looking at doing something like this as well, but I'm a bit concerned about what my exhaust may do to the rubber since it will almost point straight at it. Any issues like this with your set up? Also, may I ask where you got the heavy belt material?
Thanks,
Blaine
Adub
Twin Falls
Posted: 09/14/10 05:45pm Link  |  Print  |  Notify Moderator
ya they are on the ground, I should have taken the pics after airing up the bags!
I usually air up last after every things hooked up and just put the overloads on the stablelifts.
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
