RV.Net Open Roads Forum: Tech Issues: More Solar for "Us"
 > More Solar for "Us"
Page of 54
MrWizard
Traveling
Posted: 04/28/12 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Four about worn out golf GCs
And Four big AGM
Battery bank nomial 966 ampHrs
I thought the solar nomial was 489 watts
But after getying the numbers off of the Solarex panels ive revised that to 505 watts
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
bdosborn
Colorado
Posted: 04/28/12 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
So how many more watts do you need till you don't have to run the generator at all?
Bruce
2010 6.5'X11' TTT - Boxcar
Custom Frame, Poptop, AC, Espar Diesel Furnace, HW Heater, Sink, Shower, 12V-120V, LED Lights, TV and XM Radio, DVD Player, 300W PV Panels, PD 9140 Charger, Tongue Box, Filon Exterior, 1000W Generator, Patient Wife
Boxcar Build
KendallP
Grants Pass, OR
Posted: 04/28/12 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to throw out a WAG of double.... and more batteries. But, of course we're talkin' about an AC fridge here. Now you're getting into off-grid HOME territory, which.... still can require a generator when you've got several straight days of rain and no sun.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
BFL13
Victoria, BC
Posted: 04/28/12 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Mr Wiz is out of roof real estate. We did the stacking panels thing with panels going out in all directions like jack-knife blades. Now is the time for my latest invention.
You buy several of those thin panels that come rolled up, but instead of un-rolling them and gluing them down, you just attach them at one end sideways along your roof line and leave them rolled up.
On arrival at the camping spot, you deploy your awning and then release all those rolled up solar panels to un-roll down your awning.
Now I need to invent a roll-up mechanism for the panels so you can then roll up your awning on departure.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
CA Traveler
The Western States
Posted: 04/28/12 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Or buy the longest enclosed trailer you can tow. Car inside, solar on roof, pop out solar slides on 4 sides, at least 4 wind turbines and a very large solar tracker.
You're set to go anywhere, plug in and power your S&B house and BBQ under the pop out slides.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
CT_WANDERER
E. Lyme, CT
Posted: 05/22/12 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hey MR Wizard question on your BS2000 controller. Are you running all your panels throught it? 489 watts? I am doing calulation for what I want to set-up for my system and I am understanding that the BS limits is 340 watts. I was planning to use 3 Kyocera KD140SX, but was concerned at being at 420 watts. Am I readding something wrong with either the BS spec or is there something I am not following that you done? Are you pushing all this through the your BS controller? Thanks
smkettner
Posted: 05/22/12 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the Wizard is driving the BS2000 with 505 watts.
Controller clamps the amps at about 25.
Only ideal conditions will have the full wattage available.
Some power is not put into the battery (lost) when amps are limited.
675 watts solar
MrWizard
Traveling
Posted: 05/22/12 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
yes all panels are connected to the 2000e
the peak amps output ever recorded was 25.37
peak watts output recorded was 351 watts
when I tested the Xantrex c40 I recorded a peak of 28.74 amps 399.4 watts
this was with cloud fringing/lensing on a day with intermittent rain & clouds
even though I have 505 watts worth of panels they are mounted flat and never get full total face "theoretical " output value from them
pianotuna
Regina, SK, Canada
Posted: 05/22/12 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hi CT,
The owner of the Rogue 3024 suggests that for a flat install up to 500 watts would be safe. I much prefer the Rogue for this size system than any other controller. If the system is going to be larger than 500 watts, I'd jump to the Tristar MPPT 60 amp unit.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
CT_WANDERER
E. Lyme, CT
Posted: 05/22/12 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
OK Thanks Guess so far I am understanding what i am planning on doing.
edit spelling
* This post was edited 05/23/12 08:59am by CT_WANDERER *
Page of 54
