RV.Net Open Roads Forum: Tech Issues: 275 hp cummins
 > 275 hp cummins
houhjc
at the pump, tx
Posted: 11/17/10 08:11am Link  |  Print  |  Notify Moderator
would like to increase this to about 350 or so. whats offered? its in an 02 monaco.
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
P3TC
Glendale Springs, NC
Posted: 11/17/10 08:28am Link  |  Print  |  Notify Moderator
I have looked into this several times, and after weighing the economics...it just wasnt there, I get good mileage now, and the torque increase is not that much.....my 275 works just fine.
BY the way, mine is a 5.9....if yours is an 8.3 its a different animal.
But in answer to your question, Banks makes the best kits overall.
Bill
">1998 Monaco Diplomat
hershey
Albuquerque,(fulltime) NM, USA
Posted: 11/17/10 08:40am Link  |  Print  |  Notify Moderator
Before attempting a hop-up, find out how much hp and torque your Allison can handle. I have a 270 hp Cummins and my Allison it nearly maxed out. But, even if I could increase the hp, I'm afraid I'd suffer a loss of fuel mileage. Fuel mileage keeps my mind occupied as I spend the extra time climbing a hill [emoticon]
hershey - albuquerque, nm
Someday Finally Got Here
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
houhjc
at the pump, tx
Posted: 11/17/10 08:56am Link  |  Print  |  Notify Moderator
Bill
i assume the 8.3 is.....a little better than the 5.9?
J Walker
Oakton, Va
Posted: 11/17/10 09:09am Link  |  Print  |  Notify Moderator
I believe the OP has a 5.9 ISB. A 2002 date says it might be a 53 block. If so in no case increase the HP. The 53 block can crack and greater stress just increases the chances.
Jim Walker
2014 Thor Palazzo 33.2, 6.7 Cummins, 2100 Allison
2009 Malibu
P3TC
Posted: 11/17/10 09:12am Link  |  Print  |  Notify Moderator
Bill
The 8.3 makes more torque and horsepower can be raised easier....so yes it is probably better.....not sure on fuel mileage.
Bill
jauguston
Bellingham, WA
Posted: 11/17/10 11:44am Link  |  Print  |  Notify Moderator
If it is a 2002 ISB 275 is about it. I had a 1999 210 ISB and uprated it to 275 RV specs. Aftermarket hop up programmers for the Dodge/Cummins will NOT work on a Cummins 1998.5-2002 ISB motorhome engine. I know I tried. Several said their stuff would but none worked. Totally different engine management computer.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Triker33
Homestead, FL
Posted: 11/17/10 05:02pm Link  |  Print  |  Notify Moderator
Banks has a kit to increase the HP & torque.
It won't even be near 350 HP with the kit and you will need the Allison 3060 transmission.
MPG will stay the same no less and no more.
Boost pressure will go from 23 PSI to 33-34 PSI.
I have had the kit on a 12 year old 53 block, for over 5 years now with no problem.
I can't remember how many years ago it was, when the last report of a 53 block cracking in a MH.
Anyone else know of any lately?
I think all of them are old enough, if they hadn't cracked by now. It probably isn't going to happen.
If you have a 53 block just warm it up slowly.
* This post was edited 11/17/10 05:13pm by Triker33 *
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
wolfe10
Posted: 11/17/10 05:54pm Link  |  Print  |  Notify Moderator
Before this discussion can reasonably go forward, you need to determine if you have the Cummins B or C engine and if you have the Allison 6 speed transmission with electronic shift pad or 4 speed Allison.
Brett Wolfe
2003 Alpine 38'
Fishinghat
Western Washington, USA
Posted: 11/17/10 07:14pm Link  |  Print  |  Notify Moderator
At 275 HP, it most probably is the 5.9 Cummins, or ISB engine, and not the 8.3 or ISC engine. Almost all, if not all of the 8.3's of the 2002 vintage would be in the 325 HP and up range.
My concern would be overheating of the cooling system, overheating the turbine, and exceeding the limits of the transmission. I wouldn't do it.
If you're dead set on upgrading the power, consider replaceing the engine/transmission with an 8.3 ISC combination from a wrecked motorhome.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
 > 275 hp cummins
