sniperj78
Calgary, AB Canada
enblethen wrote: Brake and turn signals use a different filament in your light bulbs.
Check ground
Check fuses under the hood.
What make and model of TV?
TV is 2010 Ford F150 Crew Cab
enblethen
Moses Lake, WA
Check for fuses under the hood driver's side. There should be two fuses for each function.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
go wild
Minneapolis, MN
I had the same problem. Replaced the 7-pin vehicle connector (i.e. the end attached to the truck) and problem solved.
2007 Jeep Commander 4X4 HEMI
2010 Jayco 17Z
Chuck_S
Broadview Hts, OH, USA
Did you test the trailer as I suggested earlier? Trouble shooting the truck is pointless if the trailer lights don't work properly.
If the trailer is good, stop in at the auto parts store this afternoon and get a 12v test light. Usually has a probe connected by a wire to an alligator clip. Clip goes to the truck frame. Turn the 4-way flashers on and insert the probe in the 9 o'clock and 3 o'clock contacts on the back of the truck. Should flash in sync with the taillights on the truck. There should be a diagram on the closed cap showing what does what.
The trailer turn/brake signals both connect to the same 40a fuse in the trailer tow fuse panel under the truck hood. It's on top of the radiator shroud in my Expedition.
There's a junction box under my camper where the umbilical cord connects to the trailer wiring. If the trailer lights test bad there may be a loose connection or two in there.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
sniperj78
Calgary, AB Canada
Thanks for taking the time to reply Chuck. I will try these things and post back what I find out.
sniperj78
Calgary, AB Canada
Ok, now I feel stupid. Using all the advice above I checked the trailer lights first by connecting a circuit tester between the 12V and turn light connectors on the umbilical cord (checked out fine)...so I know the wiring and the bulbs on the trailer are fine. So, it must be the TV. I re-checked all the fuses and found the right one this time. Sure enough, blown fuse. What I learned, there are two fuse boxes on my TV (2010 Ford F150). Hopefully someone else will learn from this thread what I did. Great tips everyone and how to trouble shoot what I am sure is a very common problem!
Chuck_S
This is the trailer tow fuse/relay box on my Expedition. Entirely separate from the main box. I'm guessing the F150, the parent of the Expedition, is similar. The fuse and relay for the either the Brake Controller or 12v Trailer Battery Charge circuit (I forget which!) needed to be inserted, they came in a separate bag.
As for the fuse don't feel any stupider than me. I had a problem with the range hood on my Roo 23SS that turned out to be a fuse as well. I was getting ready to pull new wiring thru the trailer to fix it when I discovered the overlooked fuse.
-- Chuck
edited 06/14/11 07:49am by Chuck_S *
phishheadmi
Northern Michigan
I wonder if anyone's still watching this thread. I have a trip planned tomorrow, and of course when I pulled my TT out of storage a couple of days ago, the brakes and all exterior lights (turn sigs, brake lights and running lights) didn't work. I cleaned the contacts in my 7 pin connector and got the brakes working but still no lights. I've traced the wiring back from the umbilical cord to where it disappears into the RV and everything seems to be OK. Next, I replaced the 7 pin connector thinking maybe that was the problem. Where do I go from here? Oh, the guy at my local RV store had a 7 pin tester and everything's working fine on the TV. So, now I have brakes, but no lights...any ideas? Since all the lights quit working, I have to assume it's up stream from each individual light. HELP, PLEASE!!
RandK-M
NY
Mine lost brake and turn after sitting for the winter too. It turned out to be a little corrosion in the bulb connector itself.
With the turn signal on, I twisted and played with the bulb a bit and it came on. I just cleaned the connector, added some bulb grease, and all is good now.
Jayco 17Z
Dodge Ram 1500 Quad Cab
Prodigy P2
Equal-i-zer Hitch
US Navy Veteran
Chuck_S
I doubt anyone was watching this thread until you woke it up!
The left and right brake/signals are on separate circuit from the running lights. If the truck is OK and nothing on the trailer is working the first suspect is the ground.
-- Chuck
