RV.Net Open Roads Forum: Class A Motorhomes: wheel alignment
 > wheel alignment
joe0508
knoxville
Posted: 08/21/11 07:28pm Link  |  Print  |  Notify Moderator
i going to replace all four of my tie rods and i have a 92 chevy p30 chassis.i have to do a wheel alignment afterwards and understand that it is hard to get the correct specs done on a chassis like this.I read that they will do the specs for a commercial truck instead of a motorhome chassis.When i take it in what can i tell the tech to garrentee me a correct allignment.
wagonmaster2
northcentral oklahoma
Posted: 08/21/11 09:07pm Link  |  Print  |  Notify Moderator
I had a '93 P-30 chassis and a '97 P-30 chassis aligned a couple times each at a local small front end shop and don't remember having to make any distinction on the type of vehicle.
Wagonmaster2
newxmar
East Otis, MA
Posted: 08/22/11 07:00am Link  |  Print  |  Notify Moderator
Suggest a truck alignment place and if they are experienced they will know where to set the alignment.
May not be the manual numbers. I had wandering on a W-22 chassis and took it to an experienced heavy duty alignment place. They said the alignment was the manual numbers and that setting would result in wandering. They set the alignment to their numbers and handling was then excellent. After 40,000 miles there was some slight tire wear on the edges due to alignment (?) or inflation pressure (?), but it did not matter as the tires had to be replaced due to 7 years of age.
toolman1
Cerritos, CA.
Posted: 08/22/11 07:09am Link  |  Print  |  Notify Moderator
I run a small FE shop in the OC, CA. and you had better have a hard look at even more of the front end components. Those P-30's are killers of the left bellcrank, draglink, and lower ball joints, in addition to the tie rods. Super Steer makes an indestructable bell crank, and if needed, look into another source for lower ball joints (other than Workhorse) cuz they want a $$fortune$$ for the ball joints. Good Luck.
See ya out there!!
Hooliville member #128
Gary & Lynne.
'04 Dolphin 5320 WH-22 370W Solar
22' Mighty Mover Trailer, 60W. Solar.
Sand Sprite 4. 2.3L EFI sand buggy
'91 Toyota 4X4 longbed Truck
2011 Black Lab "Lucy" for both of us ">
sjholt
Henderson, NV
Posted: 08/22/11 08:22am Link  |  Print  |  Notify Moderator
Make sure you get 6 degrees of caster, it will steer better.
Skip
1996 32' Monaco Windsor DP
Cummins 5.9L 230+ HP
5 Airbags in front- 4 in back
 > wheel alignment
