RV.Net Open Roads Forum: Towing: Towing jeep wrangler behind 5th wheel
Search only in Towing
Open Roads Forum  >  Towing
 > Towing jeep wrangler behind 5th wheel
wls
Harrison, Mich. USA
Posted: 09/01/11 06:15am Link  |  Print  |  Notify Moderator
Anyone do it, or tow any vehicle behind a 5th wheel. I want to flat tow. I can't remember off hand what the length is that you can tow right now, but correct me if wrong, I believe in Mi. you can get a adorsement on your license to tow longer???
Bernie
2008 Dodge 3500 Dually
2005 Sandpiper 335 RLT 37'
mpfireman
Cook County Il
Posted: 09/01/11 07:25am Link  |  Print  |  Notify Moderator
Do a topic search, it should keep you busy for a few hours. I do not like double tows... Truck, Trailer, Another trailer.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
webhannet
Southern Coastal Maine
Posted: 09/01/11 08:28am Link  |  Print  |  Notify Moderator
How much of a frame do you think that fiver has? It's certainly not designed for this. I'd be curious what the trailer manufacturer would say about this?
Even IF you were able to escape legal restrictions, I doubt the functionality or the safety factors would allow you to do it for any length of time or distance. The VERY FEW times I've seen this done, it was with utility trailers.
steelpony5555
Copperas Cove Texas
Posted: 09/01/11 08:43am Link  |  Print  |  Notify Moderator
There is a guy on here I know that does...look up Neversweat7 and IM him..I'm sure he would give you a hand....
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
carringb
Corvallis, OR
Posted: 09/01/11 12:38pm Link  |  Print  |  Notify Moderator
If I remember right, the max length is 65' in Michigan, so I suspect that would be an issue for you. Yes, there is an endorsement for Michigan drivers (out of state driver's don't need it, and cannot get one).
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, ~350,000 miles
New Desert Fox in the works!
johntank
Oxford, Ms 38655 USA
Posted: 09/01/11 03:04pm Link  |  Print  |  Notify Moderator
I think with your rig and towing something like a two door Jeep you will be very close or maybe over the 65' max length that most states have, yes some states do have a longer max length. Good luck on what you do, do.
fullautodave
currently in Rogers, Ar
Posted: 09/01/11 10:22pm Link  |  Print  |  Notify Moderator
I flat tow a 2009 Wrangler behind my 38 foot Mobile Suite fiver. I don't remember but I think I am about 72 foot long. Most states that it is legal in are 65 or 75 foot limits. I have probably towed around 25-30,000 miles this way and have never had a problem in a state that allowed it. The hitch that came on my trailer from the factory is rated at 3500 pounds and I think 500 pounds tongue weight (?). I am a little over the 3500 but pretty close. I am from Arkansas and dont need an endorsement although I do have a Federally mandated CDL which doesn't apply to non-commercial vehicles.I can barely tell my Jeep is behind me and the only thing I do different is slow down a little. You must remember you have another 15-20 foot and 3500 pounds behind you. It's not for everybody but it is not unsafe if you drive accordingly.
2009 Mobile Suites TKSB3
2008 Ford F-450 Superduty
2009 Jeep Rubicon toad
1999 Bigfoot C1011FR
mowermech
Billings, MT
Posted: 09/02/11 06:47am Link  |  Print  |  Notify Moderator
In Montana the maximum length is 65 feet for a single trailer, 75 feet for double trailers.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
wls
Harrison, Mich. USA
Posted: 09/02/11 06:21pm Link  |  Print  |  Notify Moderator
I thought my jeep would weigh close to 3000#'s, reason I did'nt think too much about the weight, was I see alot of pretty big boats being towed behind some 10" framed 5th wheels, probably not quite as heavy as my jeep but close, maybe a boat person will chime in. I can still leagally pull close to 12' more, if I remember right, but then again, in mi, I have seen some very long setups, I know they are probably close or over 65'
wls
Harrison, Mich. USA
Posted: 09/02/11 06:22pm Link  |  Print  |  Notify Moderator
do you have a brake setup on the jeep? thanks
