RV.Net Open Roads Forum: Tow Vehicles: 2011 F350 6.7 Turbo Trouble
Search only in Tow Vehicles
 > 2011 F350 6.7 Turbo Trouble
scotthas
Redcliff, Alberta
Posted: 10/23/11 08:36am Link  |  Print  |  Notify Moderator
Well I hate to admit... but we have a new turbo on order from FORD engineering. We have had trouble with the turbo dumping boost when RPM's between 1000-1500, boost pressure goes over 10 psi. This is under a slight load to heavy load and what ever the speed if it stays with in 1500 RPM and boost goes over 10psi. This has been going on since around the 15000KM give or take. Techs had it for about a week and a half, there efforts along with FORD engineering come up with zip... There solution was replace the turbo as every test was "a pass" and they are at a loss.
Before this was the NOX sensor that was talked about on here at length otherwise it has been great until we have had this issue come up. I have tried to search this forum but haven't had a lot of luck so I wanted to put this out and see if there is anyone else out there having this problem.
Getting a little apprehensive with this being a new truck and how they cost now!!! I hope we didn't make a huge mistake...
Happy campers
2011 FORD Lariat 350 Super Duty
2013 Forest River Sandpiper 365SAQ
45Ricochet
North Idaho
Posted: 10/23/11 08:48am Link  |  Print  |  Notify Moderator
At least FOMOCO is covering it under warranty
I'm sure you'll be fine soon.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
ricatic
Home
Posted: 10/23/11 09:09am Link  |  Print  |  Notify Moderator
There have been very few turbo issues in the 6.7 powered Ford pickup trucks. There gave been some problems with the very different turbo used in cab/chassis trucks.
Great news that your Ford actually has a warranty...mine did not
http://www.ford-trucks.com/forums/1107341-drum-roll-please-and-the-loser-is.html
Regards
Ricatic
Debbie and Savannah the Wonderdachsund
2009 Big Horn 3055RL
2006 Chevrolet Silverado 3500 Dually LTX with the Gold Standard LBZ Engine and Allison Transmission
2011 F350 Lariat SRW CC SB 4WD 6.7 Diesel POS Gone Bye Bye
coolbreeze01
Redding, Ca
Posted: 10/23/11 09:16am Link  |  Print  |  Notify Moderator
I don't understand "dumping boost". What is the design pressure at 1,000 to 1,500 RPM?
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
scotthas
Redcliff, Alberta
Posted: 10/23/11 10:08am Link  |  Print  |  Notify Moderator
coolbreeze01
I'm not sure what the pressure should be... all I know is that the wastegate is dumping as it gets over 10psi as long as the RPM's are staying in between 1000-1500. I know that before this was never an issue, I remember when driving the same terrain before it was well over 10 psi and there was no noise of the wastegate valves making noise. When the RPM get over 1500 it stops and the Boost pressure will go much higher with out dumping pressure.
Yes it is a good thing that this is all warranty.
4*phun*2
Canada
Posted: 10/23/11 10:15am Link  |  Print  |  Notify Moderator
A WEEK and a HALF? No thanks. I left Ford for that very reason. Too long in the shop and incorrect diagnostics.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
scotthas
Redcliff, Alberta
Posted: 10/23/11 10:23am Link  |  Print  |  Notify Moderator
I hear ya but when you dump closed to $70K what is someone to do... I'm not made of money so they are my only option. I just have to hope that they get it fixed. If not then I go to the other dealer we have here and hope for the best...
C Schomer
Buckeye, Az.
Posted: 10/23/11 10:33am Link  |  Print  |  Notify Moderator
I hope the new turbo fixes it but I would think it would be a wastegate control/computer problem rather than the wastegate, itself. But sometimes I shouldn't try to think! Craig
camping man
Central Fla.
Posted: 10/23/11 10:37am Link  |  Print  |  Notify Moderator
I don't drive Dodge because of the truck, paint and a flashy interior don't get you home.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
scotthas
Redcliff, Alberta
Posted: 10/23/11 10:58am Link  |  Print  |  Notify Moderator
The wastegate control has been checked out all "PASSES" and info sent to FORD engineering. Also program updates and such also... So this is where we are at.
