slickjimmy792
texas
Can a chevy silverado 1500 4.8 v8 with the 3.23 and a tow capacity of 4700 tow a 4100 lb dry weight travel trailer in the mountains?
BuckBarker
Treasure Coast Florida
Perhaps on the downhill side only! I had a 4.8 in a Tahoe and it would barely move itself in the mountains. I certainly wouldn't do it.
mkirsch
Rochester, NY
4100 dry weight will easily be over the truck's 4700 trailer rating by the time you load up.
Frankly, it's not going to perform well on the flat, let alone in the mountains. You will certainly spend a lot of time at 25-30MPH in 2nd gear.
It WILL tow it, just not very fast.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
skipnchar
Topeka or somewhere else
Why would you want to take an empty trailer to the mountains? Just curious.
fla-gypsy
North Florida
Oh it could do it but you wouldn't like it a bit
gmcsmoke
Butler
Yes, but you'll not like the results on flat ground.
slickjimmy792
texas
Well looks like I will be sticking with a popup. cannot find a travel trailer in the weight range for the right price.
kaydeejay
SE Michigan, USA
slickjimmy792 wrote: Well looks like I will be sticking with a popup. cannot find a travel trailer in the weight range for the right price. Don't forget, any weight above a 150# driver has to be subtracted from that 4700# Max Tow Rating.
You probably need to be looking for a trailer weighing no more than 4200-4300# FULLY LOADED.
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
dirt dawg
southeast
I have that setup and I'm afraid to pull a 6X12 cargo trailer with it. Lot of HP, but no pulling power, grabs 2nd gear going up a hill in cruise control!
Dirt Dawg
2005 Coachmen Freelander 2890QB
2000 Gold Wing CSC Trike
slickjimmy792
texas
found another camper I think I will buy. Weighs 2986 GVWR is 4500
