artsyone
California
We are just purchasing the unit and there is no information on the use, care, etc. of the Spartan Tag axle, we have no prior usage and would like to learn, can you help. Thanks,
vladen
Louisiana
humm that info should be in your chassis book ??? other than bearings and brakes if its got em thats all I know.
Vlad's busy workings
All hope is gone
Fishinghat
Western Washington, USA
We had a tag on our previous coach and never had any problems. You may or may not have an option to raise the tag for parking. Other than that, you don't need to do anything differently except buy two extra tires when you buy a set. A tag axle is an excellent way to give you plenty of cargo capacity and still be within weight limits.
Contact Spartan with your chassis number if you have any specific questions.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
Roadpilot
NH Seacoast
Fishinghat wrote: We had a tag on our previous coach and never had any problems. You may or may not have an option to raise the tag for parking. Other than that, you don't need to do anything differently except buy two extra tires when you buy a set. A tag axle is an excellent way to give you plenty of cargo capacity and still be within weight limits.
Good advice. The only thing I can add is that there is an air release on the tag. It doesn't raise the tag, but removes the air holding it down.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
MountainAir05
New Mexico
You can get most of the manuals and stuff here.
http://comnet2.newmarcorp.com/instance1/servlet/WebDispatcher?mode=logon&env=Env77&user=retail&psswd=retail
BASSMAN50
INDIANA
What year ?? while we were at Spartan their was a guy in with his. I think it was an 08 or 09 Essex and they was replacing the bearings in the tag. I guess they had put some chinese bearing that was defective and the airbags were defective. This is what he told us....I know he was not a happy camper.
thunderstruckhd
Ft.lauderdale and Key West,Florida
Spartan chassis are the best in my opinion. The chassis itself need no maintainance other than the normal grease job. The tag itself needs no maintainence. Brakes under normal conditions will last a couple hundred thousand miles plus,yes you read that right. The engine will require the normal diesel maintainance such as oil changes, coolant, trans services,etc.
Recomended engine service schedules can be found online under the engine manufactures website. Newmar and Spartan is an excellent combo...
Prevost H3-45 Featherlite Vantare
500HP Series 60 Detroit Diesel
Assorted trailers,toys and toads
And Zoie the Doberman.(01/26/01 - 07/23/11) R.I.P.
