RV.Net Open Roads Forum: discuss towing w/ Cad 500 vs other car
Search only in Tow Vehicles
 > discuss towing w/ Cad 500 vs other car
Page of 19
whisperide
Golden Spike area
Posted: 06/29/12 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
A bit of research on the IRS shows it was only the '03-up Expedition, too new to be a real option. And the payload rating is also far too low.
More progress tomorrow.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
whisperide
Golden Spike area
Posted: 07/02/12 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I braved the heat and tried tilting the 5er hitch, only to discover that the pins weren't bottomed in the cradles. I will need to cut windows in the deck.
The left end needs to be bobbed about 1/8" to clear the hatch strut, so I won't bend the new struts when I get them.
whisperide
Golden Spike area
Posted: 07/06/12 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I just ordered Moog CC851 springs and Firestone 4103 airbags for the rear of this car.
I think I can just use the bags with the original springs for bumper-hitch, or just the new coils with no bags.
Stock rear coils have a static load rating of 520-580 pounds each, and a rate of around 105 pounds per inch, with an installed height of 10-10.25", an inside diameter of 4.30", and a wire diameter of 0.485"-0.500"
These spec at 1325 # / 440# / 10.0" / 4.25" / 0.703"
These bags are rated at 1000# per pair.
Cost to my door, for all of this, new, is under $170.
whisperide
Golden Spike area
Posted: 07/07/12 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just got the gas tank back in, no more difficult than before the bracing. Pics soon.
whisperide
Golden Spike area
Posted: 07/09/12 11:59am Link  |  Quote  |  Print  |  Notify Moderator
whisperide
Golden Spike area
Posted: 07/12/12 05:55am Link  |  Quote  |  Print  |  Notify Moderator
My new Firestone airbags arrived yesterday, they are blue, and so is the tubing for the air lines. I'm quite pleased, but pics will wait until the springs arrive.
whisperide
Golden Spike area
Posted: 07/13/12 05:24am Link  |  Quote  |  Print  |  Notify Moderator
Looking at the GM spring support brackets that were transferred from the stock axle to this axle, they are rather thin steel, and I'm feeling concern that they won't hold 3 times their original load.
Looks like I'll be making my own HD replacements today.
whisperide
Golden Spike area
Posted: 07/13/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Here's the stock setup:
And here are the 2 sets I'm making, one for the Dana 60, one for the GM 10.5":
whisperide
Golden Spike area
Posted: 07/14/12 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Outboard there was the original intent, but I laid the other one inboard:
And liked that better. So how to attach it?
Wait, that can be turned inboard also:
whisperide
Golden Spike area
Posted: 07/14/12 09:16am Link  |  Quote  |  Print  |  Notify Moderator
BTW, these are 2" x 2" x 0.250", 36" long, and will be bolted at both ends. I cut 4, 2 as seen and 2 more underneath. But the ground is still very wet. So, back to trying this in my asymmetrical-designed car:
I call that a problem. Minor, but needing attention.
Page of 19
