RV.Net Open Roads Forum: Fifth-Wheels: 5th Wheel Level Enuff?
 > 5th Wheel Level Enuff?
cruz-in
Southern Maryland
Posted: 01/20/12 04:35pm Link  |  Print  |  Notify Moderator
Hi All,
Attached is a pict of my 5th wheel and truck after the install of the Trail Air Tri-glide Pin box. Tri-glide raised the front of the 5er a bit. So what do you all think...level enuff?
It tows real well...
Thanks in advance for the opinions....
LewMichele&Paws
At a gas station in Cowlitz County WA
Posted: 01/20/12 04:40pm Link  |  Print  |  Notify Moderator
...looks like you've tried everything.
'06 Ford F350 V10 CC 4X4 SB auto 4.10
'01 Arctic Fox 235H (5'er)
Don't lose your head...to save a minute...you need your head...your brains are in it...Burma Shave
States visited in our RV...
Coyotecprs
chicago
Posted: 01/20/12 04:53pm Link  |  Print  |  Notify Moderator
It does not look too bad. Weighing the two axles on the trailer separately would show you the weights on each axle.
2005 Dodge Ram 2500, 5.7 Hemi
2007 Jayco Jay Flight 30.5 BHS
cruz-in
Southern Maryland
Posted: 01/20/12 05:06pm Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Running a bit nose high....
Got any adjustment left in pin box or hitch to drop nose?
If not......guess you will tow it like it is.
Nope, already used all those adjustments up....
It sure tows nice with the trail air tri-glide...
cruz-in
Southern Maryland
Posted: 01/20/12 04:44pm Link  |  Print  |  Notify Moderator
Yeah, after reinstall of the pinbox as high as possible into the frame and running the truck's airbags at near minnimum, this was as level as we could get it. seems to tow real well...
Old-Biscuit
Across the USA
Posted: 01/20/12 04:45pm Link  |  Print  |  Notify Moderator
TMBLSN
Washington State
Posted: 01/20/12 05:10pm Link  |  Print  |  Notify Moderator
Definitely weight it. Check the load on each tire, individually. Your rear tires will have more load.
Is there any room for adjustment in the trailer axles? My Jayco had 3 different mount positions. I have able to 'lower' the axle almost 5", which really raised the 5er.
Before the adjustment, I had over 1000# difference between the axles. After the adjustment, ~100#.
tvman44
Southwest Louisiana
Looks good to me, I have seen much worst.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
webslave
Clearville, PA
Posted: 01/20/12 05:12pm Link  |  Print  |  Notify Moderator
The ground where your picture is taken from slopes a bit left and right from the rear wheels of your truck. I'm guessing that it would look pretty darn level from a slab of concrete or a flat parking lot.
Looks good to me mentally raising the nose of the truck a bit to compensate for the slight slope. If it tows fine, have at it. The Tri Glide TrailAir is a bit pricey, but, I love mine and hope you enjoy yours as much.
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
j2catfish
Newport, NC, U.S.of.A.
Posted: 01/20/12 05:17pm Link  |  Print  |  Notify Moderator
Some manufacturers state that "slight" nose high when travling is OK. Yours looks slightly high to me. Good to go!
Catfish
I would weigh all wheels one at a time to ensure thqt the weight is evenly disttributed.
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC Mustang (LDO)
Semper Fi !
