rtaylor0830
davidsonville md
Do you use the ez lube feature and if so how do you do it to make sure you are not putting to much grease, and does this take away having to repack the bearings as often.
Howaboutnow
AZ
I have been putting 1 to 2 greese gun pumps into the EZ Lube bearing once a year for 6 years. Last year I became concerned about how well that was working. Had the hubs pulled and the bearings hand packed. The shop told me everything was fine and the bearings were not worn. Have about 25,000 miles on the 5th wheel. It seems to work for my situation.
azjeffh
Chandler, AZ
rtaylor0830 wrote: Do you use the ez lube feature....
After more than 7 years, the answer is No for me. I would rather have them checked than blindly putting grease in.
Others have used it with success.
Jeff
Wonderful wife Robin
05 F250 Supercab PSD w/Tow Command
05 HR Savoy 29RKS
SailingOn
Central Texas
Dexter, manufacturer of the EZ Lube axles, intended the feature to prevent water intrusion when boat trailers are immersed in water in the launch process. Otherwise, pumping grease into the axle serves no purpose but probably does no harm. Turn the wheel as you add grease; use a manual grease gun, not the powered versions; use the correct grease. See www.dexter.com.
Buck: 2004 Wilderness Yukon 8275S
AJ: 2010 F150 ExtCab, 2WD, 6.5' bed, 5.4L V8, 6A, Max Tow: 2030# payload.
jmtandem
western nevada
I have used EZ lube and it takes quite a bit of grease to get it to come back out the exit area. I would think that every 5-6000 miles it might not hurt to actually repack the bearings. Even using EZ lube check check the 'play' in the bearings to be sure you are OK. Use the recommended grease to not mix greases that might not be compatible. It is really very easy to grease with EZ lube.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
jjj
Lancaster,Ca.U.S.A.
I took mine off and replaced with a regular cap to get rid of the zert fittings that show. I never used mine and did not trust them. I just check and repack each year to keep an eye on things.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
fla-gypsy
North Florida
Find info here;
http://www.dexteraxle.com/faq_s
Bachus
Stratford, Ontario, Canada
I use mine (although my Cougar has Alko axles, and their version of the EZ lube). I'm always amazed at how much grease you have to pump in. Typically about 50 pumps per wheel with a manual grease gun. However, I have had no problems, and manually check the bearings every other year. Where does all that grease go??
Dean and Tracy Bachellier
Isobel,Evelyn, and Stuart
2012 KZ Durango D355BHS quad bunk with 5 slides
HiJacker 16K double pivot slider
2011 RAM 3500 SRW Crew Cab 4X4 CTD
"It's five o'clock somewhere...."
BB_TX
McKinney, Texas
I used it on mine. Jacked one wheel at a time. Pumped grease with a hand pump slowly as I kept the wheel turning constantly while I was pumping. The new grease I was using was red (Mystic JT-6 Hi Temp grease, one of the ones recommended by Dexter), the old grease was a dark grey. I pumped until I saw red grease come out the front indicating that the new grease had pushed the old grease out.
It did take a lot of grease. About 3 tubes as I remember it, about yr and a half ago.
Dexter instructions
Allworth
Orlando, FL
I do mine about every 5,000-6,000 miles. Turning the wheel per Dexter's instructions.
It took a lot of grease the first time; not so much on subsequent applications.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
