RV.Net Open Roads Forum: Tow Vehicles: Exhaust Brake
Search only in Tow Vehicles
 > Exhaust Brake
Gonecamping444
MI
Posted: 03/01/12 10:59am Link  |  Print  |  Notify Moderator
Hi,I have a 2007 1/2 Chevy Silverado Diesel & been thinking about getting an exhaust brake put on,Anybody know anything or have a PRXB Exhaust brake from pacbrake?Not sure if i need one since by fifth wheel only weights 7,800 #s but loaded 10,000 #s,We do alot of traveling out west & it would be nice going down hill.Is it really worth the price?Thanks
coolbreeze01
Redding, Ca
Posted: 03/01/12 11:12am Link  |  Print  |  Notify Moderator
Best money you can spend on your truck. I wouldn't own a diesel without one. Check BD Performance also, they may build one for your truck. Good luck.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
NRALIFR
Truck Camping Out West
Posted: 03/01/12 11:19am Link  |  Print  |  Notify Moderator
I've got a US Gear exhaust brake on the truck in my sig. Great product, and I love it. I can descend most any grade with no or very little use of the service brakes. It's one of the best mod's I've put on my truck, and I've put many.
2001 Lance 1121 on a 2010 F450
MB1
I'm on a boat
Posted: 03/01/12 11:20am Link  |  Print  |  Notify Moderator
Have you considered having your truck tuned with EFI Live to use the turbo vanes as a "turbo brake" ? This is essentially how the '12 GM Diesels are tuned.
Many people like the flexibility of having switch on the fly tuning with the option of running more power or mileage as well.
donn0128
Pronounced Ore-gun
Posted: 03/01/12 11:25am Link  |  Print  |  Notify Moderator
Have you actually had any experience using the Allison grade brake feature yet? I found that it worked quite well when I was pulling my 13K+ fiver. I could maintain 45-50 MPH easily coming down 7% grades. In fact I often times had to use throttle to keep it at 45.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
4x4ord
Canada
Posted: 03/01/12 11:26am Link  |  Print  |  Notify Moderator
I don't think you need an exhaust brake on an '07 Duramax as the 6 speed transmission will gear down and rev the engine high enough to get adequate braking - especially with only a 10,000 lb trailer. If you try your truck out and feel you would really like an exhaust brake I too would recommend programming to use the turbo vanes.
2011 F350 SRW short box 4x4 CC 6.7 PS King Ranch
B&W TurnoverBall and Companion
2003 Citation Supreme 34 RLTS
Gonecamping444
MI
Posted: 03/01/12 11:46am Link  |  Print  |  Notify Moderator
Hey Thanks for the info,Stupid ? What gear do you put it in too to slow down & how do you do it when going down hill,I always left it in drive.Thanks alot
donn0128
Pronounced Ore-gun
Posted: 03/01/12 11:59am Link  |  Print  |  Notify Moderator
Tow haul on top of the hill on D. When speed increases tap the brake pedal. Transmission will downshift on its own. Need more braking tap the pedal again. It will drop another gear. I am not afraid to override the transmission and manually shift to keep speeds where I am comfortable.
JIMNLIN
out here
Posted: 03/01/12 12:01pm Link  |  Print  |  Notify Moderator
The Allison and your VVT (varible vane turbo) are the grade braking feature and should work fine with that size trailer. If you just have to have a actual exhaust brake I would look at the Pacbrake PRXB system.
Some folks with the DMAX/A install the Banks Speed Brake system which is a software package that closes the turbo vanes more which restricts more/longer for more exhaust braking power.
Also killerbeeperformance.com is another great sourse for info on reprograming the DMAX/A for more exhaust braking performance which is basically what GM did with exhaust braking on the new '11 and up DMAX/A trucks.
'97 Park Avanue 28' 5er 11200 gvwr two slides
coolbreeze01
Redding, Ca
Posted: 03/01/12 12:04pm Link  |  Print  |  Notify Moderator
While the tow/haul is a nice feature, an exhaust brake is better by a bunch.
 > Exhaust Brake
