RV.Net Open Roads Forum: Class A Motorhomes: gen set help!
 > gen set help!
David0725
Posted: 03/12/12 10:20pm Link  |  Print  |  Notify Moderator
I have a Onan diesel generator Model # 7.5 DKDFJ S/N B943118548 SPEC#56905D I have a radiator leak and need to fix it or replace it but I cant seem to find one. And I also whould like to replace the motor mounts.can someone tell me were to find parts for this gen set.
thanks.
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
PapPappy
Wilmington, NC
Posted: 03/12/12 10:25pm Link  |  Print  |  Notify Moderator
Check with local Radiator shops to see about having that one fixed. I will probably be much cheaper than buying a replacement from Onan/Cummings.
There is a Used parts place in Texas, but by the time you have it shipped and all, it may cheaper to have the old one fixed.
Also, are you sure it's the radiator, and not a hose or loose clamp, or even a bad radiator cap leaking?
Good Luck
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
dirtyharryo
United States
Posted: 03/13/12 04:44am Link  |  Print  |  Notify Moderator
If you can not find one or get it fixed, put some black pepper in it that will stop most leaks, I have done that a lot over the years it works better than most stop leaks sold in stores.
chaffeekid
Chaffee, Mo, USA
Posted: 03/13/12 05:03am Link  |  Print  |  Notify Moderator
You might check the RV Salvage places, Colaw comes to mind.
Colaw Rv Salvage
I'm sure there are a bunch more but you can give these guys a call they may have the parts.
Happy Trails
Jim
MGySgt USMC(R) 61-91
N0LZS
Wife, has put up with me for 49 years
Three hyper chihuahua's
Good Sam a pound rescue, Sassy and Bambi
2001 Fleetwood Expedition Diesel Pusher
Toad 2011 Dodge Ram 1500 Crew Cab 4 X 4
fourmat
NJ
Posted: 03/13/12 06:11am Link  |  Print  |  Notify Moderator
most radiator shops can fix it or recore it
2009 Challenger
 > gen set help!
