RV.Net Open Roads Forum: Dinghy Towing: Learn Something New Everyday!
Search only in Dinghy Towing
 > Learn Something New Everyday!
Dave n Holly
Lansing IL
Posted: 03/14/12 03:38pm Link  |  Print  |  Notify Moderator
I recently had my 08 Jeep Wrangler Toad in for a recall notice. I engaged a conversation with a Jeep Corporation Rep in the Service area as he saw the Baseplate on the front and asked me what I do to prep to Tow it?? Its a 6 speed manual so its able to be towed 4 down, no lock on steering so no need to disconnect any Battery power as the keys dont have to be in it....
I told him I Shift the transfer case to Neutral and also manual transmission to neutral and thats it, as the manual says,
I was in Awe when he said I should ALWAYS have the Trans in first gear while towing........
That was a new one on me, he showed me online the Service Bulletin that Jeep put out in regards to this....
Guess I will tow it in 1st Gear from now on...lol
2009 Coachman Freedom Express 31
2009 Ford E450 Super Duty Triton V-10
Quadra Bigfoot Auto Levelers
Old-Biscuit
Across the USA
Posted: 03/14/12 03:56pm Link  |  Print  |  Notify Moderator
OK I'll bite.......WHY?
Corkey05
Washington State
Posted: 03/14/12 04:05pm Link  |  Print  |  Notify Moderator
With the transmission in neutral there is nothing to prevent the gears from spinning up and they may not get lube. With the transfer case in neutral, and the transmission in first the gears are prevented from moving.
I was told the same thing for my Blazer.
Even though I have a driveshaft disconnect, I tow my Blazer in park in Park (auto trans) for the same reason. There is enough friction to spin internal gears when in neutral.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
mowermech
Billings, MT
Posted: 03/14/12 05:58pm Link  |  Print  |  Notify Moderator
I always put my Rubicon in gear to tow it, transfer case in Neutral.
That's what the Owners Manual says to do.
I use 6th gear, just in case the unthinkable (and unlikely) should happen, and the transfer case should somehow get in gear (or I don't get it fully in Neutral).
I would rather have the engine spinning along in high gear at 65 MPH than in low gear at 65 MPH!
I don't think the engine would last long at that RPM!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
MPond
Thousand Oaks, CA
Posted: 03/14/12 06:42pm Link  |  Print  |  Notify Moderator
I do the same thing - use 6th gear instead of 1st when flat towing. Just as Mowermech says, just in case the unlikely scenario occurs and the transfer case comes out of Neutral.
I've discussed it with a Jeep mechanic that I trust, and he couldn't think of any reason it should be 1st gear specifcially, and that any gear would prevent the tranny from spinning just the same.
I asked him about the newer JK Wranglers as well when my sister was looking for a Jeep toad, and he said the same thing applied to the newer manual trans. Then again, she changed her mind to an automatic at the last minute, so she tows it in Park.
2003 Country Coach Intrigue, Cummins ISL 400
Toad: 2006 Jeep Wrangler Unlimited (LJ) toad, with just a few mods...
Other rig: 2005 Chevy Silverado 3500 Duramax Dually / Next Level 38CK Fifth-wheel Toy Hauler w/ quads, sand rail, etc...
Dave n Holly
Lansing IL
Posted: 03/14/12 06:43pm Link  |  Print  |  Notify Moderator
Why What?
MPond
Thousand Oaks, CA
Posted: 03/14/12 06:46pm Link  |  Print  |  Notify Moderator
Why What?
I think Old-Biscuit was asking why they would recommend towing with the trans in 1st gear.
Dave n Holly
Lansing IL
Posted: 03/14/12 06:51pm Link  |  Print  |  Notify Moderator
I never asked why,
Its what they recommend in a service bulletin he showed me online that he says was an update to the owners manual that year, he's a Jeep Service Rep out of Dearborn Michigan and thats good enough for me....
rk911
Wheaton IL
Posted: 03/14/12 08:19pm Link  |  Print  |  Notify Moderator
we tow our jeeps (03 wranger, 10 liberty) with the txfr case in neutral and the tranny in park.
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Old-Biscuit
Across the USA
Posted: 03/14/12 09:22pm Link  |  Print  |  Notify Moderator
Dave n Holly wrote:
I never asked why,
I always ask WHY when shown something. Must be my upbringing......always was asking WHY, WHY, WHY. I like knowing the reasons behind something
Always towed my old Bronco in neutral and didn't run into a problem (that I knew of).
Thanks to those that supplied the WHY!!
