Hi there, I just upgraded (not sure)from a class A to a 5th wheel.
What is a good hitch to buy, the trailer is light 9700 lbs the truck is a 2010 ford 1/2 ton 4x4. I'm not planning to do a lot of travelling as we lease a lot on an annual basis but the odd weekend we will go somewhere. Help, a green 5er.
I don't think any of the 1/2ton Fords are rated to pull 9700lbs. But, to answer your question, and if you have a short bed, you will need some type of slider hitch, either manual or automatic. SuperGlide makes a really nice auto slider that's rated to 12K lbs. I think Curt also make one that's less expensive.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
If you don't need a slider I would definitely recommend the B&W Patriot hitch. You can check them out at the www.turnoverball.com or www.tweetys.com/. I would stay away from the low end bar type kingpin latch (Reese Pro 15K) and go with the jaw clamping latch.
oldbiker7 wrote: If you don't need a slider I would definitely recommend the B&W Patriot hitch. You can check them out at the www.turnoverball.com or www.tweetys.com/. I would stay away from the low end bar type kingpin latch (Reese Pro 15K) and go with the jaw clamping latch.
X-2 I just installed mine and couldn't be more pleased. The quality is
excellent. The shipping packaging is a work of art in itself. The powder coating is perfect and assembly is a snap as all parts fit perfectly.
And, the price, just $399.00 with free shipping. See link below.Patriot Hitch
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
1/2 tons and decent sized 5'ers dont usually mix too well. That being said, take a look at the "Hi-Jacker" hitches. They have a damn near 'fool proof' system. I have a short box, towed for 6+ years, and have never gotten myself into a jam where I would even consider using my slider hitch option. However, it is peace of mind.
i just bought a trailer in florida and pick up a truck for my son in texas. we needed to put a hitch in the truck bought a 14k trailer is 9800lbs worked fine all the way home.
