SRT
Head of the Lakes, MN
When we had our house built had the builder run a line from the RV pad down to the septic tanks. The tanks were sized for 2 1/2 baths (3 bedrooms). Never have had a problem. I figured that we were gone for a while the level in the tanks would be lower and could handle the inflow.
SRT
2000 32' HR Vacationer with Banks
1998 Subaru Outback Ltd. 5 spd
Brake Buddy & Blue Ox Aventa II tow bar
FMCA #266040 HRRVC #84109
jassrnj
Bath, PA
I have a cleanout pipe between the house and the tank. I just pull the cap, hook up the hose an dump. It really makes life easy when you come home with full tanks.
MTPockets1
The sewer clean-out access is alongside the house - we just tap into that and screw the cap back on after dumping. I believe most homes have a clean-out somewhere - ours was found about 3 inches under the surface, but now we know where it is.
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
ScottG
Bothell Wa.
chinook507 wrote: past-MIdirector wrote: We know a lot of people who have done just that. Make sure you check with your township on any ordinances. In our county it can vary a lot. We have a couple townships where you have to call it a wash out to legally install and in most you can not leave the hose in except to dump.
X2 on the wash out!! What they dont know waont hurt them! That is my intention when I replace my sewer line here at my place.
X3 What you want to do will work fine and there's no sense in getting some local gov. into it unless you just want to spend more money for nothing.
Scott, Grace and Wesly
H0NDA eu2000i
Sailbad
Bernardo, New Mexico or Quartzsite
el.jefe wrote: Anybody ever installed a place to dump the trailer tanks at home? We've got a septic tank, and looking at it it just doesn't seem like it would be all that complicated to run a pipe at a downward angle from near the driveway to the tank so I could empty the trailer tanks at home. We camp without full hookup a lot and generally not too far from home, having the option to come home and dump rather than wait in line at the dump station is appealing. Also because I'd like to use the camper as kind of a guest house this summer, and a working bathroom would be a big benefit.
Anybody done this who can point me in the right direction?
You can put a "clean out" anywhere you want. If it happens to be near the drive way and happens to be large enough to handle an RV dump, so be it. I wouldn't mention it to anyone. Just do it.
I know it's worked fine for me.
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
Keep Your Powder Dry....This Ain't Gonna Be Fun
jdkd123
Northeast
Perhaps consult with Dave Matthews.
JDKD123
2005 Coachmen CONCORD
GO SOX!
dave54
Northeast CA.
As already mentioned, many local governments will levy a fee on extra sewer hookups, but installing a cleanout is no problem.
Make sure you tell everyone it is just a cleanout.
Log off and go camping!
Dutch_12078
Great Sacandaga Lake, NY
Our town building inspector had our contractor rename the "4 in. RV dump fitting" on the plans for our new septic system as a "4 in. clean out". No other changes were required to handle the motorhome waste.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
Charltons
Battle Ground, WA
dave54 wrote: As already mentioned, many local governments will levy a fee on extra sewer hookups, but installing a cleanout is no problem.
X2 on this we installed a "clean-out" as well works great. No fees...
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
