oshdriver
Riverbank CA
I have a onan marquis 5000. Gonna change the oil in it. How much oil does it hold? Something tell me 3 1/2 quarts. Am I right?
Thanks
Polishnurse
Schodack, NY
I don't beleave you are, one quart seems more like the number I remember. Check out the manual. The Manual
chili's trip
Full time
oshdriver wrote: I have a onan marquis 5000. Gonna change the oil in it. How much oil does it hold? Something tell me 3 1/2 quarts. Am I right?
Thanks
5.5 Onan takes 2qts.
2005 Fleetwood Bounder 32W 8.1.
2009 Honda Fit Sport
OldF**t
Crossville, TN
chili's trip wrote: oshdriver wrote: I have a onan marquis 5000. Gonna change the oil in it. How much oil does it hold? Something tell me 3 1/2 quarts. Am I right?
Thanks
The correct answer. When refilling you have to dribble it in slowly to get an accurate fill.
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2009 Kymco Xciting 500Ri
1 wife and 7 cats
sssooo
Ohio
2qt is rite,someone needs to invent a container that screws into the fill hole and holds 2qts so you can just fill it up and let it go!
I'm not that smart,I'd buy one
Sully2
Cincinnati
No manual evidently??
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Captain_Happy
Abilene, Texas
I've got an older Onan 5.5 generator and right near the oil fill it states 3-1/2 quarts. Dodn't even have a owners manual either. If you think 2 qts is right, just put in 2 qts and check the oil level to see if it's up to the full mark, if not, add oil until it does.
Yankee Clipper
Cairo, GA
My Marquis 7000 uses 3 1/2 quarts of 10W30 and a Fram 3600 filter. HTH.
Don't forget the air filter.
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
1991 Explorer Sport 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS
Not overly concerned about depreciation with this rig...
deaop01
Mansfield, Ohio
One thing you need to do is have it level. My 5.5 (2002) has to be level to get it full. Don't have it here now but think mine is either 1.5 or 2 qts including the filter. It will take about 15 mins to fill it. Takes it real slow.
Good luck
Ron
Betty and Ron
2002 Bounder 31W
8.1 with 5 speed Allison
2 slides
2005 Colorado toad
bartletttraveller
Bartlett, Tennessee
From cummins/onan website spec sheet
Lubrication: Full pressure positive displacement lube
oil pump, spin-on, full flow lube oil filter, low oil pressure
shutdown, dipstick
Oil capacity: 2.0 qt (1.9 L) including filter
Jim & Judy
2003 Coachmen Aurora
3380MBS
