RV.Net Open Roads Forum: Fifth-Wheels: Double Tow 5'R and Boat
 > Double Tow 5'R and Boat
Mile High
Denver, CO
Posted: 04/12/12 09:34am Link  |  Print  |  Notify Moderator
I was 72 ft. Colorado maximum 70 ft, Nebraska 65 ft.
50 ft will get you pulled over if you can't keep it in the lane.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
highlife4me1
MN
Posted: 04/12/12 03:18pm Link  |  Print  |  Notify Moderator
pompano wrote:
From Dec. 2000 to Dec 2004 I towed my 18.5ft Yarcraft boat/with trailer behind my 3280RL Montana fifth wheel. Towed with Dodge 2500 Cummins from Baja Sur, Mexico to Lac La Ronge, Saskatchewan.. and back...each year.
I had the boat hitch welded to the Montana's frame by an expert machine shop. Never had a problem with the weight or any swaying.
Some states do not allow this type of towing. Minnesota does not!
Minnesota DOES allow double towing however the rig in your picture would be well over the length limit. So I guess your last statement is true for your rig.
45Ricochet
North Idaho
Posted: 04/12/12 04:28pm Link  |  Print  |  Notify Moderator
Mile High wrote:
That's got to be a pain backing down the launch ramp
That's a pretty heavy floater for a double tow. Must have got the Wednesday build from Lippert.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
Mile High
Denver, CO
Posted: 04/12/12 05:11pm Link  |  Print  |  Notify Moderator
It is heavy for a double tow, but just right for a triple tow!
I did have some spring hanger issues, but I don't know if it was just Lippert or the weight of the boat. Everything replaced since that picture except the boat, and we use 2 tow motors now.
pressure_welder
brandon
Posted: 04/12/12 06:23pm Link  |  Print  |  Notify Moderator
My wife and i also double tow our rig, were in manitoba canada. Havent double towed with this camper yet, i am just about to fab up and reiforce the frame to be more than capable to tow our 1850 crestliner, about 3500ish lbs. Camper has an IBEAM frame at the back theirs two 12" sections of 2 x 4 x 3/16" structural tubing welded to the ibeam frame which holds the rear bumper onto the camper. I believe ill utilize the existing 2x4 tubing and build off of that, itll make the reciver at the perfect height. Overall when were all hooked up well be roughly 68-69 feet. Legal length in manitoba is 71ft. All in all i think theirs more misconception about double towing like this, the boat shadows the camper quite nicely, just have to learn how to take corners just a little wider!
2012 Duramax Denali Dually
2003 Triple E topaz 29' luxury touring edition.
1850 crestliner sportfish w/ 150 optimax
Mile High
Denver, CO
Posted: 04/12/12 06:34pm Link  |  Print  |  Notify Moderator
pressure_welder wrote:
.....just have to learn how to take corners just a little wider!
Actually that is a misconception itself. The boat swings out much wider than it normally would on the back of the truck because of the 5er pivot at the rear.
After the first couple of turns I realized I would not need to worry about wide turns, just drive it as if the boat wasn't there.
jalichty
Lander, Wyoming 82520
Posted: 04/13/12 07:19am Link  |  Print  |  Notify Moderator
Mile high,looks good to me. We towed double/triple for 18 years with our little Eagle 215 SD and never had a problem. By the way, I was, and am, not good enough to back the boat down the ramp with the trailer attached. I don't think that Mile High does that either. Towed boats ranging from about 2,500 to 5,000 pounds behind that little trailer.
John A. Lichty
45Ricochet
North Idaho
Posted: 04/13/12 10:00am Link  |  Print  |  Notify Moderator
No sense of humor You must have missed my "rolled eyes" icon.
mowermech
Billings, MT
Posted: 04/12/12 08:02pm Link  |  Print  |  Notify Moderator
"It is heavy for a double tow, but just right for a triple tow!"
Let's see...
Truck (tow vehicle), trailer, trailer...
Sure looks like a double tow to me.
But, if you want to call it a "triple tow", go for it!
Just don't get snarly when somebody asks you if towing three trailers is REALLY legal.
It will happen sooner or later...
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
Mile High
Denver, CO
Posted: 04/12/12 08:18pm Link  |  Print  |  Notify Moderator
I will, thanks.
