RV.Net Open Roads Forum: Tech Issues: Repairing Electric Cord on Old Camper
 > Repairing Electric Cord on Old Camper
1995brave
San Antonio, TX
Posted: 04/13/12 11:08am Link  |  Print  |  Notify Moderator
Take some pictures and post them for us. It sounds like you still have the wiring from the 50's, twisted, cotton covered wiring. You may have to rewire the whole trailer.
93Cobra2771
East Tennessee
Posted: 04/13/12 12:15pm Link  |  Print  |  Notify Moderator
I HIGHLY suggest you get a qualified electrician in to look at what you have. Yes, it will cost you, BUT it will save you from miswiring the plug and causing bad things to happen.
I'll also say this. Typically, a camper that old is going to need some work done on it, will you be doing the work or do you have someone else lined up to do it? If you aren't very experienced in handyman type fixes, you might have bought yourself and expensive project.
Richard White
2011 F150 Ecoboost SCREW 145" 4x4
Firestone Ride-Rite Air Springs/Air Lift Wireless Controller
2006 Sportsmen by KZ 2604P (30')
Hensley Arrow
mlts22
Austin, Texas
Posted: 04/13/12 02:18pm Link  |  Print  |  Notify Moderator
X2 on that. Wiring from the 1950s is almost certainly not going to have a third grounding wire, or items that are essential safety items. I'd get an electrician with RV knowledge to rewire it up properly, so you have a ground and no chance of the outer skin of the trailer ending up energized.
I mentioned this on a previous post, but it also can't hurt to have a switch rated circuit breaker located nearby where the cord comes in. This way, you can flip the circuit breaker off, plug/unplug your cord, flip it back on and not worry about arcing.
Gary.
Yukon, OK
Posted: 04/13/12 03:43pm Link  |  Print  |  Notify Moderator
If you check the plug and it is indeed a 15amp look closely at the plug and notice that the one prong on the male plug is larger than the other one. Then if you are going to attempt putting a new plug on yourself look carefully at the plug and see if one of the prongs is also larger than the other! When you take the old wires off the old plug make sure you check to see which wires come off the larger side of the plug so you can put them on the larger side of the new plug or you will have your RV wiring reversed, AND THAT IS NOT GOOD. Good Luck Gary.
* This post was edited 04/13/12 04:15pm by Gary. *
NanciL
Bakersville, NC, USA
Posted: 04/13/12 04:39pm Link  |  Print  |  Notify Moderator
Take a look at the cable labeling.
If it is number 10, it is 30 Amps.
If it is number 12 it is 20 amps
Jack L
Jack & Nanci
MsMandyJohnson
KY
Posted: 04/14/12 04:27pm Link  |  Print  |  Notify Moderator
How can I post pictures?
larry cad
ohio
Posted: 04/14/12 08:43pm Link  |  Print  |  Notify Moderator
Where in Ky are you located? We will be traveling thru KY in a couple of weeks and if you are close to our route, would be glad to stop and take a look.
Our Travel Blog
