MsMandyJohnson
KY
How can I clean some old cushions? I cannot take the covers off because it looks like the cushions have heavy cotton in them or some type of old filling in them. I wanted to clean them because I have allergies. I was thinking of steam cleaning them, but wasn't sure if that is a good idea. Any siggestions are welcome. Thanks again.
Moved to Tech Issues forum from DIY.
edited 04/13/12 04:54pm by an administrator/moderator *
mockturtle
WA
Mightn't it be better to just replace them?
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
Eycom
32043
Unless you're dealing with a delicate fabric, such as silk, hot water extraction would be a good choice. You can rent a 'Rug Doctor' at most large grocery chains. Get the accessory "upholstery tool" and a good de-greaser to pre-spray on the fabric. Use as directed. Let the chemicals do the work. I'd also pick up some Scotch Guard and spray on the fabric after the cleaning to replace the protection. For big jobs, you can find the Scotch Guard in the gallon size for a lot cheaper at a janitorial supply house. You'll need a pump-up sprayer for that application. Good luck.
RVn Full-time
recycler
michigan
mockturtle wrote: Mightn't it be better to just replace them?
x2
the fill might be causing the problem since it will hold lots of dust
1968 franklin 11fk
back to my 93 cummins
MsMandyJohnson
KY
They don't smell bad. I just wanted to clean them as best I can. I really don't have the money to put out for new cushions. Maybe I will try steam cleaning them and allowing them to dry.
phillyg
Front Royal, VA
X2 on the steam cleaning, with the hand-held wand.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Chrisatthebeach
The beautiful low country of South Carolina
phillyg wrote: X2 on the steam cleaning, with the hand-held wand.
x3, and after cleaning, put them outside on a warm sunny day to dry, it will air them out and make them smell a little fresher.
Chris & Dianne plus two boys, both of them are Eagle Scouts.
Jayco Designer 3110
F250 PSD 4x4 Crew Cab
recycler
michigan
if replacement is out of the question i would steam clean or even rent a rug doctor and then put out in the sun for a day or two...
MsMandyJohnson
KY
thanks so much i plan on steam cleaning them and putting them in the sun for a day or two
Heish
United States
One method might be to cut the short seam. pull out the cotton batting (put in a large garbage bag), wash the covers, restuff the cushions and hand stitch the seam. Cut the seam as small as will allow you to get your hand in there to pull out. I just did this with two LARGE pillows. Took some time but VERY clean covers. Just a thought. Another thought is to buy new foam blanks and reuse the covers. I have an old Morris chair that had extremely hard 'horse hair' cushions and was able to order new foam pieces. I did make simple new covers cause I wanted funky leopard print. ;0)
