RV.Net Open Roads Forum: Travel Trailers: Forest River ?
 > Forest River ?
Sprinks542
Western Pa.
Posted: 04/13/12 06:24pm Link  |  Print  |  Notify Moderator
Hey guys, friends bought a 2012 sabre by Forest River last summer. He's having a problem with his bedroom slide which is electric. Will not extend out. He's hooked into shore power but has no power to inside fridge and Tv. All fuses were checked along with gfi in bathroom. Everything looked fine. Is there a disconnect he's not aware of of maybe forgot? I'm clueless with Forest River. Any suggestions?
08 Ford F-350 SD PSD CC
10 322 Fuzion Touring Edition II
07 Can-Am Outlander 800
08 Can-Am Renegade 500
LadyRVer
Posted: 04/13/12 06:28pm Link  |  Print  |  Notify Moderator
Slides normally run off battery power. Sounds like battery is dead or on battery disconnect. Can friend hook up trailer to his(her) tow vehicle and let run a few minutes to put juice into the trailer battery and then try the slide?
I had a Forest River Palomino Thoroughbred fiver 2008 but don't remember a battery disconnect on it.
Steeljag
Posted: 04/13/12 06:42pm Link  |  Print  |  Notify Moderator
Check connection to battery and battery power !
2010 Flagstaff 26RLS
2012 Ford F-150 Screw Ecoboost H/D 3.73
2006 Toyota Tundra D/C (sold)
2001 Bantam B-19,(sold)
2003 Harley Road King
The whole family,
Cold ones in the cooler, good times ahead.
Sprinks542
Western Pa.
Posted: 04/13/12 06:46pm Link  |  Print  |  Notify Moderator
It's a 2 slider, one slide extended while other did not. Also has no power to inside fridge. With shore power hooked up shouldn't everything work?
mike77leprechaun
Ishpeming, MI
Posted: 04/13/12 06:53pm Link  |  Print  |  Notify Moderator
If he got it last summer it should still be warranteed contact the dealer.
Current Rig: 2011 Salem 29QBDS Towed with a 2011 Chevrolet Silverado 1500.
Past RV's:
08 Jayco 30BHS, 02 Dutchmen 30FK, 77 Coachmen Leprechaun MMH
Past TV's:
06 Ford F-350 Diesel 4x4,02 Dodge Ram 1500 4x4,01 Dodge Ram 1500 4x4, 94 Chevrolet Silverado 4x4
ScottG
Bothell Wa.
Posted: 04/13/12 06:55pm Link  |  Print  |  Notify Moderator
The slide on FR products is protected by an auto-resetting breaker. The hard part is finding it. It could be anyplace from under the RV to inside a cabinet or behind the converter.
Scott, Grace and Wesly
H0NDA eu2000i
LadyRVer
Posted: 04/13/12 07:18pm Link  |  Print  |  Notify Moderator
None of the slides in different units we have owned worked off shore power.
Refrig,yes, if refer is turned to AUTO. Check cords where plugged in (power post) or if marine type on trailer, check to make sure that is tight. Also, is breaker on in the electric box at the pole outside? Check breakers inside of unit (probably located top part of converter box.) Also, for elec, double check the GFI outlets (usually bathroom and maybe kitchen plugs) but haven't known of those to affect the refrig.
amxpress
Clayton, NC
Posted: 04/13/12 07:48pm Link  |  Print  |  Notify Moderator
Go to the Forest River Forum site. There's a Sabre rep that answers people's questions and is very helpful. His name is Sabre Sam.
Click here: http://www.forestriverforums.com/forums/f96/
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
Sprinks542
Western Pa.
Posted: 04/13/12 07:41pm Link  |  Print  |  Notify Moderator
gonna double check with him again to make sure he's not mixed up. I'll pass info along
handye9
Park City, IL 60085
Posted: 04/13/12 07:47pm Link  |  Print  |  Notify Moderator
Could be a circuit breaker, looks like this. They are normally mounted to the frame near the battery, or, between battery and slide.
They are available at most autopart stores.
Check out my mods
08 F250 Crewcab,4X4, SB
5.4, 4.10 gears
Flowmaster exhaust, SCT tuner
12 Flagstaff 831FKBSS (TT) and 00 Maverick 8801 (TC)
Wife and I
USN MCPO (E9) Retired (active duty 1973 - 1995)
 > Forest River ?
