lwmuddy
So.carolina
If you've never soldered delicate electronic parts before check out Youtube Videos first and then practice. I tiny too much heat applied and your device becomes a paper weight. Just a thought.
rjf7g
Virginia
Take it to Batteries Plus. They have the tools to open it and the replacement battery. You will be in and out in 15 minutes and the cost will be about what you will be able to do it yourself for.
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
dons2346
Sioux Falls, SD, formerly of So. CA
One thing to look at. If the wifi is turned on and there isn't any wifi available, the battery will run down in a few hours. Make sure the wifi is turned off
NorthernLimits
Michigan
dons2346 wrote: One thing to look at. If the wifi is turned on and there isn't any wifi available, the battery will run down in a few hours. Make sure the wifi is turned off
This has not been my experience. I never turn off wifi
hershey
Albuquerque,(fulltime) NM, USA
NorthernLimits wrote: dons2346 wrote: One thing to look at. If the wifi is turned on and there isn't any wifi available, the battery will run down in a few hours. Make sure the wifi is turned off
Obviously it isn't a problem for you but the reality is: wifi ON does indeed use more battery than wifi OFF. But its nice to have the choice.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
mlts22
Austin, Texas
The contents of the ipod are stored on flash disk, so the battery being gone will not affect them. Unless one is GOOD with a soldering iron, there is a high chance of destroying the iPod, so I'd take it to a pro who has the equipment and skill to deal with batteries.
If you want a go at it yourself, I've used www.ifixit.com to good use a few times on other Apple gadgets.
NorthernLimits
Michigan
hershey wrote: NorthernLimits wrote: dons2346 wrote: One thing to look at. If the wifi is turned on and there isn't any wifi available, the battery will run down in a few hours. Make sure the wifi is turned off
The reality is that if your device runs down in a couple hours, you have other issues that are above having wifi turned on.
camping man
Central Fla.
I repair a couple a month, the videos lie, and the tools they send you are a joke, and can't release the clips at all. If you destroy it, send it to me, I have all the parts in stock for the 2-4 gens..I can even repair any damage you do to the circuit board when you rip the connectors off the board if your not careful, but it's better if you don't get that far. If you don't get that battery lying just right, when you snap it closed, you'll ruin the LCD from the back side, and you'll have all kinds of colors on the screen.I'm Level 3 trained now, and I can say phones are much easier to disassemble then the Touches, I don't like those snap together deals.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
