RV.Net Open Roads Forum: Tow Vehicles: My Ram is in the hospital
Search only in Tow Vehicles
 > My Ram is in the hospital
notruffinit
Minnesota
Posted: 04/17/12 06:39pm Link  |  Print  |  Notify Moderator
Finally took my new Cummins Ram 3500 on the road to get my 5er. Got 150 miles from home and pulled off for a bite. Came out of Culvers to find a pool of tranny fluid on the ground underneath. Anyway, had it hauled to the local dealer and diagnosed at a broken tranny cooler line. Sure hope it didn't ruin the tranny. Dealer said it still had fluid in it. No trouble codes were set. And it was still shifting ok when I shut it off before eating. Gonna try again this weekend. Gotta get the rental car back anyway.
'11 Ram 3500 Cummins
'12 Cameo 34SB3
brirene
midwest
Posted: 04/17/12 06:54pm Link  |  Print  |  Notify Moderator
Hope it all works out for you. Sounds like you dodged a bullet (oops, no pun intended!).
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
FishOnOne
Katy
Posted: 04/17/12 07:17pm Link  |  Print  |  Notify Moderator
If your tranny temp did not overheat your probably OK.
As a precationary step I would have the dealer flush the tranny and add new fluid if you think it might have ran low on fluid.
45Ricochet
North Idaho
Posted: 04/17/12 07:32pm Link  |  Print  |  Notify Moderator
Stuff happens, hopefully everything is alright. I guess you have a few years left on warranty I think Dodge will cover it, but you never know now days
Just My Opinion but I would never flush a tranny unless it was out of the vehicle sitting in a stand, you know the kind that are TOAST already.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
dodge guy
Bartlett IL
Posted: 04/17/12 07:45pm Link  |  Print  |  Notify Moderator
Sounds like a non-issue! get it fixed and keep on truk`n!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
tktplz
Lake Bistineau, Louisiana
Posted: 04/17/12 07:50pm Link  |  Print  |  Notify Moderator
Replace the cooler line. Drop the pan put in a new filter then fill and drive. Don't know anything about newer Dodge transmissions but that's what I'd do on my Tacoma.
"Confidence is the feeling you have before
you fully understand the situation"
1999 Toyota Tacoma Pre-Runner
TorkLift Tie Downs
2010 Travel Lite 690FD
2007 Honda ARX1200T3D
2008 Yamaha Zuma 50 Scooter
2010 "Blue" Bulldog, "Luna"
Camped 10 Days 2012
Crazyfoe
Posted: 04/18/12 05:38pm Link  |  Print  |  Notify Moderator
Once repaired I'd make sure the whole tanny including the torque converter fluid is changed and any (if) filters are included. Hope your back up and running w/o incident...happy truckn'
04' Chevy Silverado 2500HD 496 cu in - Allison
'06 Keystone Cougar 304BH
1 Honda eu2000i generator
Drawtight Activator
Huskey Weight Distribution System
1 Spazzed Weimaraner
camping man
Central Fla.
Posted: 04/18/12 06:21pm Link  |  Print  |  Notify Moderator
That's just getting the bugs out of it. Know how many I did PDI's on when I worked for GM, that had problems before they could go from the carrier truck to the lot, probably 3 out of 5. Any thing from vibrations,unplugs electrical connectors,leaks,fuel gauges not working,caps under the hood missing,bent pulleys,rubbing exhaust systems on the frame, missing bolts,etc.,etc.. A bad line is one of the easier fixes, feel lucky.
05 Dodge CTD NV5600 6speed (100K Mile Club) / 97 Sprinter 5er
dodge guy
Bartlett IL
Posted: 04/18/12 05:12pm Link  |  Print  |  Notify Moderator
JimInMich wrote:
2011 model and had a trans line failure already?
WOW! it only took 6 posts to get that response! LOL
JimInMich
Mi
Posted: 04/18/12 11:46am Link  |  Print  |  Notify Moderator
11 Chevy Silverado Ext.Cab Z-71 4x4, 5.3 v8, 3:43 w/locker, Factory tow package, Equal-I-zer 1200#, Curt Class V Receiver
12 Cougar XLite 27RLS ( 960# Tongue, 6740# Gross as loaded)
Just the Wife and I.
