RV.Net Open Roads Forum: Truck Campers: Lance 820 water pump problem
 > Lance 820 water pump problem
ahsn36gp
KY
Posted: 04/18/12 02:01pm Link  |  Print  |  Notify Moderator
I have a 2000 Lance 820 that I purchased last fall. When I filled up the water tank and tried to get water flow from the faucets, nothing happened. The pump is running and when I put the valve under the sink in the "winterize" position you can hear the pump pushing air through the line. Any suggestions?
Thanks
Marty
Marty
2006 F250 CC SB 6.0, 2000 Lance 820
Raften
Northern Calfornia
Posted: 04/18/12 02:24pm Link  |  Print  |  Notify Moderator
With a pump that old you might need a rebuild kit. Easy to rebuild.
Seacraft Skipper
Lakeville, MA. USA
Posted: 04/18/12 02:45pm Link  |  Print  |  Notify Moderator
Did you look to see if you had 2 valves under the sink? One is a bypass of the water heater and the other allows you to draw water directly from the antifreeze jug.
Bob
Seacraft Skipper
"Semper Paratus"
2003 GMC 2500HD 4X4 ExCab L/b Air lift A/B.
2002 Lance Lite 915.
1972 20ft Seacraft Sport Fish.
Dick_B
Palos Heights, IL USA
Posted: 04/18/12 03:59pm Link  |  Print  |  Notify Moderator
You might try opening all of the faucets in the RV to try to get the prime back. Another trick is to elevate the anti-freeze line and add water to it to put pressure on the inlet side of the pump for the same purpose.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
