RV.Net Open Roads Forum: Class A Motorhomes: Towing a 2007 4x4 Silverado
 > Towing a 2007 4x4 Silverado
larryabbott
South Caolina
Posted: 04/19/12 08:25pm Link  |  Print  |  Notify Moderator
I want to tow my 2007 Silverado 4x4 behind my RV. What is required to flat land tow a 2007 Sivlerado 4x4?
It has a neutral switch that according to the owners manual puts the transfer case in neutral and allows you to tow the truck, but how far without damage? Does the driveshaft need to be disconnected?
How do I tie in the braking system?
Thanks.
gss036
Bellingham ,WA
Posted: 04/19/12 08:35pm Link  |  Print  |  Notify Moderator
My friend just got back from Arizona and he towed his 2007 GMC both ways and I tow my 1999 Silverado. Check your owners manual for the proper procedure for flat towing, it should in there. My older model is different than the newer models, or so I was told.
2ndhom
Eugene, Oregon
Posted: 04/19/12 08:36pm Link  |  Print  |  Notify Moderator
The best advice is to ask a dealer service department if in fact the operators manual does not describe clearly. My Lincoln's manual was not real clear so I got the "crystal clear" info from TWO separate dealers.
trickto322
Sioux Falls,S.D.
Posted: 04/19/12 08:42pm Link  |  Print  |  Notify Moderator
we tow our 08 Silverado, crew cab. No limits. Read the manual. Very simple.
The Texan
Meridian, Idaho
Posted: 04/19/12 08:47pm Link  |  Print  |  Notify Moderator
We tow a 05 GMC Sierra 4X4. You put the transfer case in N, the transmission in P, remove the key, it does NOT have a steering lock, lock the doors and it's ready to tow. There are NO restrictions on speed or distance, NO fuses to pull and it tows very easy. For brakes, we use a classic 12+ year old Brake Buddy set at the highest position for panic stop only. It is NOT a light vehicle, as ours scales at close to 6000#, ready to tow, but it is the best toad we have ever had.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Roadpilot
NH Seacoast
Posted: 04/20/12 07:09am Link  |  Print  |  Notify Moderator
We have an '05 Silverado 1500 and our procedure is identical and we use the same Brake Buddy. I've towed the truck thousands of miles all across the U.S.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
LongWeekends
Scottsdale, AZ
Posted: 04/20/12 07:58am Link  |  Print  |  Notify Moderator
I have an '07 Suburban 4x4. Yours will be exactly the same so just read the owners manual and go! It is very easy. We use a Roadmaster Even Brake to help with the stopping needs. With 5,700 extra pounds behind us, a little extra braking can't hurt!
Michael
Just me, my wife, our 11 year old daughter and our two big, hairy Goldens.
2004 Coachmen Cross Country
370DS - 300HP - 2 Slides
hammer01
Saint Amant, la.
Posted: 04/21/12 07:12pm Link  |  Print  |  Notify Moderator
I spoke with an engineer from general motors before i purchased my 2008 4x4 sierra 1500 and told him what i wanted to do. He said " these trucks are designed to but towed much like the saturn vehicles and there are no limits to speed or distance". I have been towing mine ever since and never had a problem.
