RV.Net Open Roads Forum: Truck Campers: Okay, I was wrong....bought a dually
 > Okay, I was wrong....bought a dually
Page of 14
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/23/12 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Welcome to the world of 6 wheels!
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
woodhog
NS
Posted: 04/23/12 08:02am Link  |  Quote  |  Print  |  Notify Moderator
and not being able to fit into tight spaces at Wal-Mart
This should be another point on the dually scoreboard .
Park as far away as possible for exercise walking to the store...
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
97Ford97Lance
Puyallup, WA
Posted: 04/23/12 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Nice looking set up John. When are we taking the boats to Moses?
Chris
BradW
Mayor of Flat Rock
Posted: 04/23/12 08:41am Link  |  Quote  |  Print  |  Notify Moderator
How long of a list do you want?
I'll start:
1) Initial cost - drw truck is more expensive than an srw
2) Fuel mileage - drw trucks get less mpg than srw trucks
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
jchall
Mystic, CT
Posted: 04/23/12 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I'll start:
Brad
For us coastal dwellers that can camp on beaches, many places don't allow DRW vehicles on the beaches.
BradW
Mayor of Flat Rock
Posted: 04/23/12 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I'll start:
3) Beaches - drw trucks are not allowed on some beaches
4) Home - drw trucks cannot be parked overnight in some neighborhoods
5) Garage - drw trucks will not fit through some garage doors.
Brad
wnjj
Cornelius, Oregon
Posted: 04/23/12 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Here are some minor ones:
More tires to air up / check pressure on / replace / rotate.
More light bulbs to burn out.
Rocks may get stuck between the tires.
Camper needs swing-out brackets.
3 tons
CA.
Posted: 04/23/12 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I'll start:
Brad
As previously stated, I've had both trucks under the same camper and the difference in driving stability is HUGE. Retrofitting a SRW with heavier wheels (etc), will likely cost much more than buying a DRW from the outset (there goes the initial cost & ever so slight mpg differences), nor will it ever provide the high COG driving stability a dually provides. This difference has to be experienced (not opinionated) to be properly understood. Appreciation is what follows understanding.
3 tons
BradW
Mayor of Flat Rock
Posted: 04/23/12 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I'll start:
6) Air - more tires to air up / air down
7) Lights - more light bulbs to burn out
8) Rocks - rocks may get stuck between the tires
9) Camper needs swing-out brackets
10) Ride - drw trucks ride rougher than srw trucks
11) Fenders - drw rear fenders can easily be damaged by rocks
12) Snow - snow can build up between rear tires
13) Replacement cost - more tires to replace
14) Rotation - difficult to nearly impossible to properly rotate tires
15) PSI - much more difficult to check the tire pressure on a drw
16) Flats - more difficult to change a rear flat on a drw truck
17) Flats - more difficult to know when you have a rear flat on a drw
Brad
Photog101
Garden City, Michigan
Posted: 04/23/12 11:17am Link  |  Quote  |  Print  |  Notify Moderator
I'll start:
I refuse to buy new and take the hit on depreciation. Difference on lease turn in as about the same on SRW vs DRW. Remember the dealer wants to get rid of these as quickly as possible
My "03 2500, 8.1, Ally, 4.1:1, CC, LB, got the same gas mileage as my dually. I down sized to an 02 Ranger for the daily driver.
No problem here in Michigan as we don't have to many beaches and the ones that we have on the west side, don't have a problem with dually's. Besides, if I wanted to go to the beaches, I'd buy a boat.
More expanded government. That is why, when I bought my house (years ago), I checked to see what the CC&R's and the city master plan were before I even looked at an area.
My dually fits in my garage ... without the T/C.
Come on, I am retired and I don't have a problem with bending over and checking the air in my tires.
I had the same number of lights and bulbs on my 2500.
True, but no big thing if you do a walk around before you take off or at every stop to see if there is any other damage from our illustrious great road system.
Actually this is a positive. It tends to give more stability when the T/C is off the truck.
Mine does not ride any worse than my old 2500 when empty and the dually rides much better when loaded.
All fenders get beat up with rocks. A little due diligence, after you have been in an area where you might have picked up a rick between the duals will save this from happening.
I live in a snow belt and have not found this to be a problem.
I replace my tires in sets of two. Two Steer tires, then move the current steers to the outside rears and the inside rears are replaced with the outside rears.
I only rotate my tires at brake inspection. I have the tires off already and that is when I rotate them. AND I only rotate side to side, due to my replacement plan.
I find that as long as the hand-holes are lined up, there is no extra problem.
Actually with a hub-piloted wheels, that most are using today, it only means that you have to move one tire out of the way. AND I have had times where I have singled out the rear duals to get off the road. (that was in a Class 8 rig though)
Believe me, when I have one of my rears that is low on air, I can hear the difference. I don't have to wait until there is a handling problem.
Brad
Now what is the problem with a dually?
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
Page of 14
