75charlie
vaughnsville OHIO
I am NEW to towing . I intend to tow a dodge 4x4 behind my HURRICANE.
I purchased BLUE OX tow bar & plate .The tow bar can be extended & how far need this be ??
Moved to Dinghy Towing forum from Towing.
edited 04/23/12 05:59pm by an administrator/moderator *
Robert78121
San Francisco Bay Area
I'm not sure if I understand your question. The tow bar does compress when not in use and extends to lock when in use, but it's a fixed size when towning.
Living full-time in the San Francisco Bay Area
Camper: 2004 Damon Daybreak 3285 WorkHorse 8.1
Toad: 2010 Mini Cooper Clubman S - BlueOx
Toy: 2012 Ninja 650 - Versa Haul VH-SPORT-RO
LadyRVer
x2, I have a Blue Ox but found the Roadmasters to be the same way.
1rickw
redwood City, CA USA
x3. I have a Roadmaster. It extends and locks in place automatically.
2004 Jamboree 26Q + great wife to travel with
OldF**t
Crossville, TN
It would also help to know the year and model of your Hurricane and what type of dodge 4x4 you intend to tow. A Dodge 4x4 truck (even a Dakota) might be too much for a gas rig to tow. As far as I know no Hurricane has more than a 5000 lb hitch/tow rating.
Jim
2004 Hurricane 32R (F53)
Demco Excalibar
2010 Ford Ranger 4X4
2009 Kymco Xciting 500Ri
1 wife and 7 cats
75charlie
vaughnsville OHIO
Dodge Dakota 04 4x4 the hurricane is a 97 460 ford THANKS
34 ft This is for short trips ..longest I think is 300 mi..
gotsmart
Aberdeen, WA
75charlie wrote: I am NEW to towing . I intend to tow a dodge 4x4 behind my HURRICANE.
If you're talking about using a receiver extesion to extend it further away from the truck then go as short as possible.
Also read your towbar's user manual. My Roadmaster falcon 2 manual says that the towbar should be no more than +/- 3 inches from level, from where it attached to the baseplate. I had to get an adapter with a 2 inch drop to level out my towbar. If your truck sits too high you may also need an adapter.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
OldF**t
Crossville, TN
75charlie wrote: Dodge Dakota 04 4x4 the hurricane is a 97 460 ford THANKS
Well then it depends on how much your Dakota weighs. I'm guessing that your 34' Hurricane has a gross vehicle weight of 20,500 and a gross combined weight of 26,000. The difference between the two gives you a theoretical towing capacity of 5,500 lbs but that will be limited by your hitch which is probably rated for 5,000 lbs max. Your coach may be able to tow more than 5,000 lbs but it won't be safe.
75charlie
vaughnsville OHIO
Thanks for the info OLDF**T Please clarify the won't be safe as to what my happen ????
OldF**t
Crossville, TN
75charlie wrote: Thanks for the info OLDF**T Please clarify the won't be safe as to what my happen ????
Worse case your hitch breaks and you lose the toad destroying it, damaging your coach, and perhaps injuring someone else. The hitch on your Hurricane is bolted to frame rail extensions which are in turn welded onto the ends of the existing coach frame rails. Not the strongest setup. If you overstress things they will break sooner or later.
