RV.Net Open Roads Forum: Class A Motorhomes: White roof sealant stuff...
 > White roof sealant stuff...
smkettner
Posted: 05/07/12 07:40pm Link  |  Print  |  Notify Moderator
msparker505 wrote:
Would someone please be so kind as to go to dicor.com and tell me which of the sealants is the best to reseal a rubber roof on a travel trailer. There are several listed and I don't want to get the wrong kind. All I was told is get the "white kind". Thanking you in advance.
Dicor website is hard to navigate
However this is the stuff you want from CW
Dicor Self-Leveling Lap Sealant
There are a couple colors, I just use white.
The self leveling means it will run a bit and smooth out. This is basically for flat surfaces like the roof. For a verticle surface you will want nonleveling.
For touch up I just wipe clean with a damp rag, let dry and apply right over the old. I have never had to revisit an area that I previously patched over.
The manufacturer's part number as given by CW does not work in the Dicor search box
Manufacturer: Dicor Corp
Mfg Part #: 501LSW-1
Google search 501lsw-1
675 watts solar
