davelinde
Lake Nona, Florida
A couple months back we noticed that the bedroom counter top had delaminated! We were pretty sure it happened fast since it was hard to miss and had not been there just a few week prior to seeing it. It seems that water got into the subsurface and it swelled, popping off the laminate.
At first I assumed it must be a leak from the roof and inspected all the caulking and various seals in the front corner of the rig. Nothing obvious. I've run out there every time it pours rain and I cannot find any dampness.
Now I'm noticing a bit of deformation, slight, like bumps and bubbles on both the inside and outside of the wall! It must be water getting into the wall? How? Where do I look? I want to get ahead of this but have no idea where it's coming from...
Dave Lindemulder
Tammy, Mark & Kirsten
04 Dodge 2500 4x4 SLT QC/SB HO-CTD/48RE
01 Volvo VNL660 singled VED12
09 Heartland Cyclone 3210
harold1946
Surprise Arizona
I looked at your floorplan and noticed there is a window above the counter top. I would suspect the sealing of the window has failed.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
the bear II
Torrance CA.
Check or reseal around the windows. We recently had a leak coming down the wall and determined the sealant around the outside of the windows had dried up and wasn't making a good seal. It looked ok but water was getting through. I scraped it out and resealed around all of the windows. No more leaks.
SidKaye
Mt Dora Florida, Montreal QC for the Summer
Pull a couple of screws out of the molding strips. Check for rust....if you see rusty screws, you have a leak. If so you can do whatever possible to recaulk and replace the screws with som sealant in each hole. You will still have to address the water in the wall issue.
Sidney
2003 Dodge Ram 3500 SLT,48RE, 4:10,Cummins HO Diesel,Quad Cab,LWB,SRW,PacBrake,Prodigy, X-Monitor Gauges,Line-X,Bedsaver
2002 Excel,Ltd,30RGW,Hughes Autoformer,Honda Eu1000i, ClearSpot 4G+,
http://www.kayepics.com
Beaker
Brevard, NC
Quote: Now I'm noticing a bit of deformation, slight, like bumps and bubbles on both the inside and outside of the wall! It must be water getting into the wall? How? Where do I look? I want to get ahead of this...
Having experienced water damage, you are already behind by quite a bit.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
davelinde
Lake Nona, Florida
OK... I can understand the window idea. I'd been puzzling and puzzling the roof. I also suspect the light up in the corner there. It all looks OK to me but I guess I need to start pulling stuff apart. Window first.
eHoefler
ozark mountains
Also, condensation running down the window would a possible cause.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
Frank&Renae
Madison, SD
I recently saw a video for a new RV leak detection system (sorry, I forget the name of the system). The way the system works is that a duct is mounted to one of the vent fans. A blower is then connected to the duct. The blower sucks air in from the outside and pressurizes the RV. A soap type liquid is then sprayed over the outside seams and around the window of the RV. Leaks show up as bubbles. This system is supposed to be able to find the smallest leaks.
You may want to have your RV tested for leaks this way.
Frank now without Renae
KZ Montego Bay 37CKM
2007 Dodge 3500HD DDW
Three cats -- Sunkist, Topaz, & Amber
One dog -- Rascal
Started Full Timing since March 26, 2008
JerJan10
NE Georgia
Here is a company that does leak detection:
http://www.rvleakfinders.com/default.html
Just happened to see their website, don't know anything about them.
Charlie D.
E. Texas-Orange
Check that light cover. Make sure it is installed with the drain hole DOWN.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
