RV.Net Open Roads Forum: Toy Haulers: Cold Floor
Search only in Toy Haulers
 > Cold Floor
joebedford
Jasper, Ontario
Posted: 05/02/12 07:22am Link  |  Print  |  Notify Moderator
Dirtclods wrote:
Cheaperuy some slippers and a couple area throw rugs.
X2
I got the heaviest pair of grandpa slippers I could find. Floor doesn't feel cold anymore.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
1L243
Astoria, Oregon
Posted: 05/02/12 12:34pm Link  |  Print  |  Notify Moderator
If you have hookups go with a electric oil radiator type heater. You can set th thermostat set your LP furnace a little higher as a backup. I have not camped in the 20 but have been in the 30's. We also use a heated mattress pad.
I was wondering if you decided to go with the Closed cell board if it would just lay on top of the black fabric material assuming the material can be taken down witout cutting... The board hardly weighs anything.
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
nayther
Burbank, CA
Posted: 05/02/12 02:38pm Link  |  Print  |  Notify Moderator
Remember insulation is just the trapping/making of air space, the more air pockets there are the better the insulator.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
Doughboy12
Minnesota
Posted: 05/04/12 10:42am Link  |  Print  |  Notify Moderator
Um, well, yeh, sure...half the story anyway.
IOWASTROKER
rocky mountians
Posted: 05/04/12 06:54pm Link  |  Print  |  Notify Moderator
You must NOT have A/C...If only two wires for heat only. I bought 2-inch foam sheets and cut them to fit all of the floor spaces between the aluminum sub floor. Also, cut 1 inch foam panels for your roof vents and windows...when it get down to 22 degrees. Awesome and cheap insurance to a toasty RV.
 > Cold Floor
