Gonecamping444
MI
Hi,Ran out of the graphite Slip Plate & leaving tomorrow & was wondering if anybody uses something different that would work just as good,Thanks again
C.B.
APPLETON WI USA
If you've been coating before every outing you should have enough build up to get by for your trip.
Run your fingers up and down the wear surfaces. You should be able to feel if the coating is still there.
C.B.
PS
I've read Tractor Supply sell a product similar to SlipPlate.
You might check there.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~
CB Family Fleet
Butch&Barb 13CedarCreek~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 11 Laredo
Gonecamping444
MI
THANKS C.B
gpshemi
Lapeer, Michigan
I've been using a product from TSC (my local farm store). It's called EZ-Slide. Seems to hold up well.
http://www.tractorsupply.com/ez-slide-graphite-based-coating-12-oz-aerosol-2120034
GPSHEMI
06' 3500 Dodge Ram Megacab 4x4 w/ bombed 5.9L
18K Pullrite SuperGlide w/super rails
2010 Heartland Cyclone 3612
daamac
x2 on EZ Slide. Its at Tractor Supply stores. Also cheaper than Slip Plate, and the can nozzles don't stop up as bad. I've been using EZ Slide for several years.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
Too Young to Retire
Sun Diego
The instructions for mine says to use WD 40
Chevy 3500HD Crewcab, SB, Diesel pulling a 36' Cameo
gpshemi
Lapeer, Michigan
Not on the ways...
C.B.
APPLETON WI USA
Too Young to Retire wrote: The instructions for mine says to use WD 40
The newer SuperGlides do call for the use of WD40.
Yes on the ways.
C.B.
gpshemi
Lapeer, Michigan
The ones with the delrin pad maybe?
JoeWebPage
Palisade, Colorado
C.B. wrote: Too Young to Retire wrote: The instructions for mine says to use WD 40
Yes on the ways.
C.B.
X2 on the WD40. All the new ones say to use that. Don't know about the materials used in earlier units.
2012 Durango 2500 325RL, Remote jacks, 5500 Onan, TST TPMS
2004 GMC Duramax, USAF retired
